OCS integration
Answered Question
May 20th, 2010
I have a CM 7 lab and OCS R2 Lab
I want to integrate the two,
I can't seem to find the documentation for setting up the integration with and without cucimoc
anyone?
Correct Answer by Rob Huffman about 7 years 1 week ago
Hey Dave,
Here's the doc
Cheers!
Rob
Overall Rating: 4.5 (2 ratings)
Rob Huffman Thu, 05/20/2010 - 09:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
mymite060708 Fri, 05/21/2010 - 01:05
Thanks rob, I take it the 2nd link is CUCIMOC
I could not open the first says invalid
thanks
Correct Answer
Rob Huffman Fri, 05/21/2010 - 06:10
  • Hall of Fame,
    Founding Member
Hey Dave,
Here's the doc
Cheers!
Rob
david-lima Tue, 05/25/2010 - 11:52
  • Bronze, 100 points or more
Hi Rob, hope you are well. I'm starting with the integracion of CUCM7.1 and OCS (without CUPS). To integrated and make that incoming call notifications will ring both the Cisco phone device and the user computer, allowing the user to answer the call on his Cisco phone via his computer, Do I need the Cisco Presence Server?.
Tanks for your time
Best regards
David
Jonathan Schulenberg Wed, 05/26/2010 - 10:06
    2017 IP Telephony
There were two designs prior to CUCiMOC: SIP Dual-Forking and Remote Call Control. The RCC model as described in the document provided by Rob requires Cisco Unified Presence (CUP). This is how Cisco has choosen to provide the gateway between Cisco CTI and the CSTA that OCS uses. Note that Microsoft has deprecated the RCC concept so you may not want to invest into it at this point.
The SIP Dual-Forking is effectively running two PBXs and sending a copy of every call between the two of them. In my opinion, it's a nightmare. This does not require CUP. If the user answers from MOC, then the call is an OCS voice call.
CUCiMOC is the way to go.
