DLSW remote-peer issue
tookenyip12
Hi, I wanted to ask does CISCO1841 support 2 different dlsw remote-peer? The thing is we have the below configuration running fine on a CISCO2600 but not in 1841.
ip subnet-zero
isdn switch-type basic-net3
isdn voice-call-failure 0
dlsw local-peer peer-id <address>
dlsw remote-peer 0 tcp <address>
dlsw bridge-group 1
interface Loopback0
description Loopback IP Address for site111 DLSW SNA
ip address <address> 255.255.255.252
no ip directed-broadcast
no ip route-cache
no ip mroute-cache
interface Ethernet0/0
description site111 LAN
ip address 10.51.64.1 255.255.255.0
ip route-cache flow
bridge-group 1
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn tei-negotiation first-call
ppp authentication chap
interface Serial0/0
description site222 DQ : 13464870 (512kbps)
ip route-cache flow
no ip mroute-cache
interface Serial0/1
ip route-cache flow
shutdown
interface Dialer1
encapsulation ppp
dialer remote-name KJ-7206-01
dialer pool 1
dialer idle-timeout 300
dialer string ##########
dialer load-threshold 2 either
dialer-group 1
ppp multilink
Richard Burts
Can you tell us what code you are running on the 1841, most especially what feature set it is running.
My concern is whether the code that you are running on the 1841 supports DLSW. Some feature set do support DLSW and some do not. So what are you running?
Rick
Rick
Hello, the below is the running IOS.
Cisco IOS Software, 1841 Software (C1841-ADVENTERPRISEK9-M), Version 12.3(8)T11,
RELEASE SOFTWARE (fc1)
If I remove 1 of the dlsw remote-peer in the 1841 router, i don't face any disconnection issue. I will have problem if I insert 2 dlsw remote-peer. Such issue don't happen in the 2600XM.
