Video Calls Cisco 9971
May 20th, 2010
Guys,
I am trying to make video calls via the Cisco 9971 to another 9971 on the same cluster but am not able to make a video call at all.
Any ideas on how I would set this up or point me in the right direction on how setting this up
Im running CCM Version System version: 7.1.5.10000-12
Cisco 9971 Firmware version: sip9971.9-0-2
Under Phone configuration > Product Specific Configuration Layout > Cisco Camera has been enabled and so has video capabilities.
But am not able to make a video call side by side from one to another and vice versa.
Kunal Patel
riko.arizona Sat, 06/26/2010 - 07:00
Hi.. I'm using CUCMBE 7.1.3
My CUCMBE upgrade to  Engineering Special 7.1(3.33030.1),
Cisco 9971 Firmware version: 9971.9-0-3
and Video Call between 9971 is running well.
Thanks.
If this helps, please rate.
Alcides Miguel Mon, 09/29/2014 - 12:12
Hi Kunal,
Have been able to solve this issue?
I'm facing the same problem.
Best regards,
Alcides
Sebastian Frank Mon, 10/06/2014 - 08:30
did you also set enough bandwidth between the locations and enabled Video in the regions?
