05-20-2010 09:47 AM - edited 03-06-2019 11:11 AM
Hi every body.
I was reading about how 1000 -T intererface will default to full duplex.
Let say we have two swithes,sw1 and sw2
sw1
100/1000-T interface--------------------------------------------------------------------------------------100-T Sw2
Let say on sw2, duplex and speed are manually configured as:
speed 100
duplex full
Now will sw1 default to half duplex?
Thanks a lot.
Solved! Go to Solution.
05-20-2010 10:34 AM
Hi Sarah,
SW1 will negotiate with SW2 and will be set to 100/full duplex as well.
Mohamed
05-20-2010 11:05 AM
You asked my How it negotiates if Sw 2 has negotiation disabled?
I will ask you how SW 1 will determine its port speed of 100 while its a Gig Interface ?
My answer is that , Sw1 will negotiate the speed according to SW 2 manual settings..
Mohamed
05-20-2010 11:44 AM
It chooses 100Mbps because it is its lowest available speed (safe choice)
It chooses Half-Duplex because it is its safest duplex choice
I do have a documentation to back this up;
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af0.shtml
05-20-2010 12:19 PM
Mohamed
When auto-negotiation is disabled on one switchport the switch at the other end of the link can use the Parallel detection function to determine the speed. Put simply the switch does not negotiate the speed with the other switch but it can still work it out.
However what it cannot work out without auto-negotiation is the duplex. Now as far as i know 10/100 ethernet interfaces default to half-duplex and gigabit interfaces default to full duplex. So you could interprete this to mean the port would set itself to 100 Full because of it's default setting is gigabit. But i think that would be wrong. Once the port has negotiated down to 100Mbps it then has to default to half-duplex because that is all it can do safely as Edison says.
Jon
05-20-2010 12:46 PM
John,
Thanks for your reply and clarification.
you said:
((When auto-negotiation is disabled on one switchport the switch at the other end of the link can use the Parallel detection function to determine the speed. Put simply the switch does not negotiate the speed with the other switch but it can still work it ou)).
I was refering to this point , as long as the other swith port speed sets to 100, the other switch negotiate it Or in a correct way it uses the parallel detection function of the other port speed. Thats why it becomes 100 Mbps port.
However, when I said its duplex of full, I didnt mean negotiating a duplex, but rather it defaults to its Full duplex settings becuse its a GIG Interface.
I still dont understand why the Gig port becomes half duplex in this situation? Do you have any reference for that ?
Mohamed
05-20-2010 12:58 PM
Mohammed
Yes, i think that's where we interpret it differently but to be honest i can't test it because i don't have any gigabit capable switches handy. You are absolutely correct in that a gig interface defaults to full duplex as i said in my last post. But my understanding is that if the gig interface has to fall back to 100Mbps it must also fall back to half-duplex because of the speed it is running at.
However as i said in my last post it really depends on interpretation of "gig interfaces default to full duplex". And your interpretation may well be correct and mine wrong.
Jon
05-20-2010 01:35 PM
Shaking head..
05-20-2010 02:06 PM
05-20-2010 03:28 PM
Sarah/All,
I was able to test this with 2 3750-E switches. In this scenario I am using port 1/0/48 on both switches. The switches are called switch B and switch C
When I set the duplex to full and speed to 100 on switch C switch B's interface shows 100 Full
Here is the config and show command for switch C
Switch-C#sh run in gi1/0/48
Building configuration...
Current configuration : 63 bytes
interface GigabitEthernet1/0/48
speed 100
duplex full
end
Switch-C#sh int gi1/0/48
GigabitEthernet1/0/48 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0019.e7c0.dfb0 (bia 0019.e7c0.dfb0)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:08, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
624815 packets input, 62610400 bytes, 0 no buffer
Received 284087 broadcasts (284087 multicasts)
0 watchdog, 284087 multicast, 0 pause input
2324754 packets output, 171372318 bytes, 0 underruns
Switch-C#
Switch B config and show command
Switch-B#sh run int gi1/0/48
spanning-tree portfast
end
Switch-B#
Switch-B#sh interfaces gi1/0/48
Hardware is Gigabit Ethernet, address is 0023.eb14.2e30 (bia 0023.eb14.2e30)
MTU 9000 bytes, BW 100000 Kbit, DLY 100 usec,
Last input 00:00:01, output 00:00:02, output hang never
2324827 packets input, 171376826 bytes, 0 no buffer
Received 1984388 broadcasts (1984388 multicasts)
0 watchdog, 1984388 multicast, 0 pause input
624837 packets output, 62612942 bytes, 0 underruns
Switch-B#
Reza
05-20-2010 03:36 PM
Reza
Thanks very much for testing that out +5.
Mohammed
Looks like it does indeed default to 100Mbps full duplex and not half duplex so i stand corrected +5
Jon
05-21-2010 10:02 AM
Hello Sarah,
I may be wrong but my current understanding of auto-negotation is that when it is disabled we actually disable only the modulation of the pulse train with the line code capabilities 16 bit word.
However, even if FLP would be turned off completely (as it looks like in http://en.wikipedia.org/wiki/Autonegotiation ), the ethernet frames sent by neighbor would provide its real speed (10 vs 100, as I noted 1000 Mbps can be detected by the fact that there would be activity in all 4 pairs not only on two pairs).
Each ethernet frame has a 64 bits preamble that is used to synchronize to the frame (there is no framing structure with a permanent clock like in a serial interfaces)
so neighbor speed can be sensed in one way or another.
Here we have a theorical answer and an empirical answer from Reza's tests.
We could say that humility comes from experience: many times theory and practice can give different answers, and only doing a specific test the empiric answer can be found.
The test tells us about effective implementation on network devices
Be also aware that CDP is Cisco proprietary and in any case also its standard based conteurpart LLDP it is at an upper layer in the OSI stack: a CDP frame is already an ethernet frame with a specific encapsulation (using 802.2 and SNAP with a well known multicast MAC destination)
Hope to help
Giuseppe
05-23-2010 05:16 AM
Hello Sarah,
if your objective is to perform interoperability tests it is correct to consider Reza's results the sign of an implementation that differs from accepted standards.
>> s why manufactures such as Cisco want to implement auto-negotiation process, clearly defined in 802.3 ab/z differently and cause unexpected results
This can be the result of a software programming error just to make an example or of a broad interpretation of standards.
With a valid service contract you could open a service request to TAC.
Current best practice for 10/100/1000 is to use autonegotiation at both sides.
We see some times that a link to a server can negotiate at 100 Mbps or even at 10 Mbps. The way we deal with these cases is : we try to shut/unshut the port to make the two endpoints to negotiate again, if this doesn't solve we try to change a patch cable (a damaged cable can be the root cause).
Hope to help
Giuseppe
05-20-2010 09:52 AM
SW1 will set itself to a safe setting 100/Half Duplex since it did not receive a NWAY from SW2.
Edison
05-20-2010 10:34 AM
Hi Sarah,
Mohamed
05-20-2010 10:52 AM
How SW1 would negotiate with SW2 if SW2 has negotiation disabled with static settings?
05-20-2010 11:05 AM
Mohamed
05-20-2010 11:44 AM
05-20-2010 12:19 PM
Mohamed
Jon
05-20-2010 12:46 PM
John,
Mohamed
05-20-2010 12:58 PM
Mohammed
Jon
05-20-2010 01:35 PM
Shaking head..
05-20-2010 02:06 PM
ediortiz wrote:
Shaking head..
05-20-2010 03:28 PM
Sarah/All,
speed 100
duplex full
end
Switch-C#
end
Switch-B#
Switch-B#
Reza
05-20-2010 03:36 PM
Reza
Mohammed
Jon
05-20-2010 11:02 PM
Hello Jon, Reza,
neighbor speed detection is possible, detection of neighbor duplex is not possible without auto negotiation.
First of all, 1000 Mbps uses 4 pairs (all wires in RJ-45) 10/100 Mbps uses only two pairs (wires 1,2,3,6).
so if the switch sees activity on all pairs it detects neighbor is working at 1000 Mbps.
if neighbor is set to 100 Mbps or 10 Mbps fast link pulses allows to detect the speed.
Autonegotiation is the modulation of the pulses to carry few bits of information to tell capabilities (16 bits link code word)
Ethernet is baseband and there is no framing structure between two ethernet frames there is silence. the fast link pulses are not ethernet frames but a form of baseband digital modulation that is interleaved over time with ethernet frames (a sort of TDM we could say).
I would say that after detecting neighbor speed is 100 Mbps a system not able to see neighbor duplex capabilities it should revert to half duplex, but Reza's tests shows something different.
Also recommendations have changed over time: years ago hardcoding speed and duplex was recommended. Today autonegotiation is preferred.
see
http://etherealmind.com/ethernet-autonegotiation-works-why-how-standard-should-be-set/
Final note:
compliments to Sarah that putting (what looks like) simple questions make us thinking of basic concepts
Hope to help
Giuseppe
05-21-2010 09:41 AM
Thanks Giuseppe for your kind remarks.
I have one more question
Once auto-negotiation is turned off by configuring duplex and speed under the interface, there should not be any FLP ( fast link pulses) as auto-negotiation is off. So in absence of FLP, what other activity would enable adjacent switch to determine the speed? is it cdp? how about if cdp is turned off ?
Thanks and have a nice weekend.
I would like to thank all of you who responded to my post. I am really learning a lot technical stuff from all of your experiences and knowledge.
Jon , i am really impressed with your humility. I will try to emulate that.
