Looking for a procedure for copying flash cards in Cisco 1000 Router
May 20th, 2010
We have a router where the flash card was erased. We have another router and can get the original router to work with this card. Is there a way that we can copy the reuired info from the good flash card to the erased one?
Andrew Hickman Thu, 05/20/2010 - 11:44
The ASR series of routers are not supported on this community.  The following might work though.
If you have IP connectivity between the devices, boot both with the good flash card (one after the other), then on the router with the good card, copy the file(s) to the other router to which you have inserted the bad card.  You can format the bad card first if you wish.
The following might help:
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a6744.shtml#copying_one_router
Hope that helps
Related Content
