e_mail notification backup fail
May 20th, 2010
Hi Guys,
My Customer have a solution IPCCX 5.0.2 with two Servers and would like know if is possible to do any configuration in the Server, to inform by e_mail, when the backup presenting a fail. Is it possible?
Wilson Santana
Overall Rating: 5 (2 ratings)
Anthony Holloway Thu, 05/20/2010 - 15:21
This can be done.  Look into the Alarm Configuration to get events sent to a Syslog server that supports email notifications.
Alarm -> Syslog Server -> e-mail notification
wilsonsant Fri, 05/21/2010 - 04:37
Hi Anthony,
The Customer is using the version is 5.0.2 and didn´t found the option to configure this parameter. The option that I verified was:
1) Substystem>eMail
           Mail Server
           eMail Address
2) System>Alarm Configuration
        There is not option to configure eMail
I would use the first option?
Wilson
Gergely Szabo Fri, 05/21/2010 - 05:05
Hi. The explanation above was too simple.
First, you need to install and configure a Syslog server.
Then you'll have to configure UCCX to send alarms to that Syslog server.
Second, you'll have to configure your Syslog server to send email messages.
Take a look at Wikipedia or Google for the term "Syslog".
G.
wilsonsant Mon, 05/24/2010 - 08:18
Hi Guys,
My co-worket that work with Cisco Works verify the Syslog (Cisco Works)configuration and didn´t found this option to configure.
Wilson
Anthony Holloway Mon, 05/24/2010 - 08:27
That wasn't a setting, or an option I was giving you, it was an example workflow, on how this works.
Since netbakter thought my explanation was too simple...
Step 1.  Configure UCCX to send Alarms to your Syslog server (System > Alarm Configuration)
Step 2.  Configure your Syslog server (the free version of Kiwi supports e-mail alerts http://www.kiwisyslog.com/kiwi-syslog-server-compare-versions/)
Step 3.  Enjoy
