inline mode Remote vpn users affected
May 20th, 2010
when i enabled inline mode in AIP-SSM 10 sofware version 7.0 (1) E3 , VPN users are connected but when they try to open any application ex: outlook etc , it dos'nt open , i would like to know which signature is blocking this traffic .
Jennifer Halim Thu, 05/20/2010 - 15:00
From the symtoms that you explain, normally it is the TCP normalizer engine signature that is causing the issue. Some of them are not actually configured to produce alert, so you might want to check via the "show stats virtual-sensor vs0"
The TCP normalizer engine is in the 1300 signature range.
Hope that helps.
