help me EoE vs VPLS
May 20th, 2010
Hi all,
I intend  to deploy a Layer 2 multipoint to multipoint but I still confused between  EoE and VPLS so someone can help me distinguish the difference of Ethernet over Ethernet vs VPLS, and configure examples such as NTT EoE are provided???
http://www.us.ntt.com/fileadmin/NTT-America/media/pdf/about-us/resources/GeVLAN.PDF
Thanks and best regards,
Ganesh Hariharan Fri, 05/21/2010 - 01:24
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all,
VPLS (Virtual Private LAN Services)  is a solution that can provide layer 2 Virtual Private Network (VPN) services over Ethernet networks. It uses a combination of Ethernet and MPLS to meet the needs of carriers and customers alike. VPLS allows customer networks at geographically diverse locations to communicate with each other as if they were in the same LAN.
Check out some configuration example in VPLS
http://www.cisco.com/application/pdf/en/us/guest/tech/tk891/c1482/ccmigration_09186a00801ed3ea.pdf
Hope to Help !!
Ganesh.H
minh tran Fri, 05/21/2010 - 02:29
Thanks Ganesh.H,
I see, but also Ethernet over Ethernet which layer 2 VPN NTT solution provides. I don't understand attach file which talks about differences EoE and VPLS.
Thanks all for reading my message.
Related Content
