Requery Status 6
May 20th, 2010
  • Bronze, 100 points or more
We are regularly seeing Requery 6 which triggers survivability to dial out over PSTN number.
CallRouter internal use. Script ends. The attempt to send the call to targetfailed because the caller hung up or the call was lost. Not visible to users.
REQUERY_ABORTED (6)In the case of ABANDON and DISCONNECT, the CallRouter assumesthe call has ended and ends the script. The RequeryStatus value is set to6, indicating REQUERY_ABORTED. This is used for the internal workingsof the CallRouter but is not visible to users. Which Nodes Support Target.
Has anyone seen this before?
