Visual Voicemail Login
May 20th, 2010
Hi - We are currently looking at deloying visual vmail widget on our CUCM / CUC 7.1.3 deployment.  Something we have noticed is that the login defaults to the DN of the phone; as our CUC mailbox numbers do not match DNs (we are using voice mailbox masking) is there any way we can present an alternative number as the default sign in number (e.g. external number mask) so that our users do not need to edit the presented DN?
Hope this makes sense!
thks
Brian
Overall Rating: 4.5 (2 ratings)
Jonathan Schulenberg Wed, 05/26/2010 - 09:55
  • Cisco Designated VIP,
    2017 IP Telephony
Specify the DN as an alternate extension on the subscriber mailbox. I believe it will figure it out and log the user in.
btmulgrew Thu, 05/27/2010 - 03:43
thanks Jonathan - i thought we had tried this but will give it another go.
cheers
Brian
rchaseling Tue, 09/07/2010 - 05:29
Did the alternate extension get this working for you?
If have a similar problem except our extensions have the "+" sign. I have an alternate extension with the + sign but still doesn't work.
Anyone know of a way to get the number masked or to turn off the auto insert of the extension number?
Russell
Jonathan Schulenberg Tue, 09/07/2010 - 05:38
    2017 IP Telephony
Apparently there is a more general E.164 defect that is preventing this from working: /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} CSCsv95521
The alternate extension workaround only works for Unity, not Unity Connection.
It appears that you have to do it manually for now.
