¿what is the correct power supply for WRV54G (see image)??
Answered Question
May 20th, 2010
Correct Answer by Ganesh Hariharan about 6 years 9 months ago
Dear Ganesh.H
Sorry, my post was not clearly explained:
Model: WRV54G
Purchase location: ARGENTINA
Local power system: 220v
Thank you!!
DKennedy
Hi DKennedy,
Power requirement for WRV54G is
Power5V, 2.5A
Check out the below link for specification of WRV54G
http://www.linksysworks.com/WRV54G.asp
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
KennedyD2010 Fri, 05/21/2010 - 05:46
Dear Ganesh.H
Model: WRV54G
Thank you!!
DKennedy
Correct Answer
Ganesh Hariharan Fri, 05/21/2010 - 10:38
Dear Ganesh.H
Model: WRV54G
Thank you!!
DKennedy
Hi DKennedy,
Power5V, 2.5A
Hope to Help !!
Ganesh.H
