Dynamic NAT rule on second interface breaks first interface NAT
Answered Question
May 20th, 2010
I have a Cisco ASA 5510 and i'm trying to add a dynamic NAT rule on a sub-interface so that internet traffic will work.  When i add the rule it is breaking VoIP inbound calls on a different sub-interface.  The VoIP is setup using Asterisk and Sipgate and is working via dynamic nat as there is no inbound rules for it.
Below is more detail on the setup
the 'inside' interface is where the Asterisk server is located.
interface Ethernet0/0
nameif outside
security-level 0
ip address *.*.*.161 255.255.255.255
interface Ethernet0/1
no nameif
no security-level
no ip address
interface Ethernet0/1.1
vlan 1
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Ethernet0/1.2
vlan 10
nameif inside2
security-level 100
ip address 172.0.0.254 255.255.0.0
With the following NAT rules setup for the inside interface:
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
and this works except no internet access on the inside2 interface, i need to add the following rule:
nat (inside2) 1 0.0.0.0 0.0.0.0 tcp 0 0 udp 0
but when i do this i get the following errors
4 May 20 2010 19:41:45 106023 *.*.*.226 5061 *.*.*.161 40576 Deny udp src outside:*.*.*.226/5061 dst inside2:*.*.*.161/40576 by access-group "outside_access_in" [0x0, 0x0]
The device that it should get to is on the inside interface, not inside2. So how is this happening??
When i remove the nat rule on inside2 the inbound calls work fine and we are back to the start.
Correct Answer by Panos Kampanakis about 7 years 1 month ago
By adding
the asa knows that it needs to translate the inside2 hosts.
But the ASA inspection should be opening pinholes for your sip traffic.
It looks like the inspection is opening a pinhole for the wrong interface.
Can you check what the routing table says for the *.*.*.161? The ASA needs to know if is behind the inside to open the pinhole properly.
I hope it helps.
PK
Overall Rating: 4.5 (2 ratings)
Correct Answer
Panos Kampanakis Thu, 05/20/2010 - 15:46
  • Cisco Employee,
By adding
I hope it helps.
PK
BrulinesCisco Thu, 05/20/2010 - 16:10
the routing table is as follows:
Gateway of last resort is *.*.*.174 to network 0.0.0.0
C    172.0.0.0 255.255.0.0 is directly connected, inside2
C    *.*.*.160 255.255.255.240 is directly connected, outside
S*   0.0.0.0 0.0.0.0 [1/0] via *.*.*.174, outside
C    192.168.0.0 255.255.255.0 is directly connected, inside
there is the following todo with SIP and inspection policies:
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
class-map global-class
match access-list global_mpc
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect pptp
class global-class
  csc fail-open
Cheers
Panos Kampanakis Fri, 05/21/2010 - 13:34
  • Cisco Employee,
I would suggest "sh xlate detb | i *.*.*.161" and "sh conn detail | i *.*.*.226" while the issue is happening. And also a "debug sip".
Those will show what connections and xlates are set for these ip addresses nd what pinholes are opened dynamically.
also a test to try would be to make your nats (inside) and (inside2) more explicit so they only contain the subnets for the internal hosts behind these interfaces only. Because sometimes overlapping nats could relate to pinholes not opened properly with inspections.
I hope it helps a little
PK
BrulinesCisco Fri, 05/21/2010 - 15:28
Hi PK,
After reading your first post i looked more into the SIP inspections and i modified the inspection so that it is specific to the inside interface, using similar commands to below:
hostname(config)# policy-map global_policy
hostname(config-pmap)# class-map inspection_default
hostname(config-pmap)# no inspect sip
hostname(config-pmap)#exit
hostname(config)# policy-map sip_policy
hostname(config-pmap)# inspect sip
hostname(config)#service-policy sip_policy interface [interface]
the above was copied from https://supportforums.cisco.com/docs/DOC-3866/version/1;jsessionid=0886E587D5D5E9BE05A4CAC899B85564.node0
i had to change class-map to just class if i remember correctly.
Thanks for your help.
Dan
Related Content
