05-20-2010 01:13 PM - edited 03-06-2019 11:11 AM
Issue: If we configure Port Security with a "dynamic" secure MAC address, an attached host can not gain access to the network.
Observation: If we configure Port Security with a "static" secure MAC address (not what we want), access is gained.
c3550-ipservicesk9-mz.122-52.SE.
Unrestricted network access with:
interface FastEthernet0/7
switchport access vlan 100
switchport mode access
switchport nonegotiate
no keepalive
no cdp enable
spanning-tree guard root
ip dhcp snooping limit rate 15
Application of these commands on Fa0/7:
switchport port-security
switchport port-security violation restrict
... results in a loss of connectivity for the host.
Output "following application of" dynamic secure MAC address configuration:
- show mac address-table dynamic: No longer shows the host MAC address (even after Ping from host).
- show interface fa0/7 status: Connected.
- show interface status err-disabled: None
- show port-security interface fa0/7: Secure-up, Total MAC Addresses: 0 (even after Ping from host), Security Violation Count: 0
- show port-security address: Host MAC address not listed.
The following do not resolve the issue:
- Cycling status of the interface (shutdown, no shutdown).
- Disconnecting and reconnecting the station cable.
- Cycling power on the host.
Anyone observe this behaviour on this platform and/or find a resolution?
Best Regards,
Mike
Solved! Go to Solution.
07-02-2010 09:29 AM
Michael,
I finally found some time to return to this issue. I was able to replicate your results on three Catalyst 3550 switches with the same IOS. I subsequently replaced the IOS image on them with c3550-ipservicesk9-mz.122-44.SE6.bin and although I did not perform thorough testing, it is clear to me that Port Security now operates as expected. Therefore I believe my original suspicion that the installed IOS version was either incorrect or buggy is confirmed.
Kevin
05-25-2010 01:47 AM
If you modify the aging time on that port to 1,2 minutes:
switchport port-security aging time 2
Does it recover?
What if you issue the:
no switchport port-security violation restrict
and let only the:
there, it is working?
Also in this mode (with violation default shutdown), run the show commands and see if it's learning the mac-address.
Calin
05-25-2010 07:26 AM
Calin:
Thank you for your interest in this issue.
We've amended the violation mode to the default (shutdown), but the output from "show port-security int fa0/7" continues to indicate Total MAC Addresses: 0
Likewise, the MAC address is not observed in output from "show port-security address" or "show mac address-table".
There is no indication that the address has been learned. There is also no indication of any violations to recover from.
The change in aging time did not bring about any change in behavior.
As soon as we configure a static MAC address (e.g.: switchport port-security mac-address aaaa.bbbb.cccc vlan access), network access is gained. This behavior has been re-verified.
Best Regards,
Mike
05-26-2010 12:57 AM
This issue made me curious so, I setup a C3550, with c3550-ipservicesk9-mz.122-25.SEE4 and test on one port:
interface FastEthernet0/33
switchport port-security violation protect
end
sw3-c3550(config-if)#do sh port-security int fa0/33
Port Security : Enabled
Port Status : Secure-up
Violation Mode : Protect
Aging Time : 0 mins
Aging Type : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses : 1
Total MAC Addresses : 1
Configured MAC Addresses : 0
Sticky MAC Addresses : 0
Last Source Address:Vlan : 0014.6a4d.2320:1
Security Violation Count : 0
05-26-2010 09:59 AM
Calin:
Thank you for your ongoing interest, and investigation. The following output is provided per your request.
dist-01#sh run int fa0/7
description
no keepalive
no cdp enable
dist-01#sh port-security int fa0/7
Violation Mode : Restrict
Aging Time : 0 mins
Total MAC Addresses : 0
Last Source Address:Vlan : 0000.0000.0000:0
With port-security, and after Ping to SVI:
dist01#sh mac address-table int fa0/7
Mac Address Table
Vlan Mac Address Type Ports
Without port-security, and after Ping to SVI:
Mac Address Table
Total Mac Addresses for this criterion: 1
Only one ingress source MAC address observed on Fa0/7. We've never observed a port-security violation on the interface.
Best Regards,
Mike
06-10-2010 09:49 PM
For what its worth, I am using the same IOS on a WS-C3550-24-PWR and also having problems with Port Security. I have been unable to get Port Security to register a violation and the port is never placed in the err-disabled state. Here is what I have done...
I configured my switchport as follows:
interface FastEthernet0/23
switchport access vlan 5
switchport port-security mac-address 18a9.0597.7d55 vlan access
end
I connected a laptop with MAC address 18a9.0597.7d55 to the switch port. The laptop obtained its IP configuration dynamically and I pinged several switches and routers in the topology.
I confirmed the MAC address had been learned in the CAM with a show mac address-table interface FastEthernet0/23 command.
Then I disconnected the first laptop and connected another one, which should have triggered a Port Security violation. The second laptop could not obtain its IP configuration from DHCP and even after I applied a static configuration I could not ping any hosts. Windows Vista responded with a "Destination Unreachable" error message.
This is not surprising since the MAC address from the first laptop remained in the CAM and did not age out. However, when I used the show port-security interface FastEthernet0/23 command, I saw the following...
Port Status: Secure-up
Last Source Address:Vlan:0000.0000.0000:0
show interfaces status err-disabled returned nothing.
I then reconnected the first laptop to the switch port and it operated flawlessly, proving that the port remained up.
This is not the expected behavior for Port Security. I tried working around this problem using different ports and different computers but I was never able to trigger a Port Security violation. I have never been able to force any other values for the three status fields above.
If there is a known flaw in this IOS on the Catalyst 3550 I would like to know about that.
Thank you,
Kevin
06-11-2010 04:11 PM
Kevin:
Perhaps we can assist one another. We have verified your results with similar testing here.
Host-A connected to fa0/7
We added a static secure MAC address (for Host-A) to the port-security configuration of fa0/7, and then issued the "sh port-security interface fa0/7" command:
dist01#sh port-security interface fa0/7
Violation Mode : Shutdown
Aging Time : 0 mins
Configured MAC Addresses : 1
We verified the presence of Host-A's MAC address on port fa0/7 by issuing the "sh mac address-table dynamic" command.
We successfully pinged the SVI from Host-A. Output of "sh port-security interface fa0/7" continued to indicate "Last Source Address:Vlan: 0000.0000.0000:0". Perhaps this field is intended for Dynamic Port Security only.
Host-A disconnected from fa0/7
Port Status : Secure-down
When Host-A was disconnected from fa0/7, the port status changed to "Secure-down", and Host-A's MAC address was removed from the MAC address table (verified with "sh mac address-table dynamic" command).
Host-B connected to fa0/7
When Host-B was connected to fa0/7, the port status changed to "Secure-up", and the Security Violation Count remained at "0". However, Host-B (configured with a static IP) was unable to obtain a ping reply from the SVI.
We issued the "sh int status err-disabled" command, and there were still no interfaces in an err-disable state.
We verified the presence of "Host-A's" MAC address on port fa0/7 by issuing the "sh mac address-table dynamic" command. The "configured" static secure MAC address is still that of Host-A, and not Host-B.
To eliminate other contributing factors, we amended the static secure MAC address on fa0/7 to that of Host-B. Host-B was then able to ping the SVI successfully.
During our test, we did not observe any indication of a Security Violation, or any interface being placed in an err-disable state. This was contrary to our expectations as well.
Our Issue
We have not been sucessful with Dynamic Port Security on this platform (c3550), with the specified IOS (c3550-ipservicesk9-mz.122-52.SE).
An attached host has not been able to access the network without specifying a "static" secure MAC address.
Are you able to confirm this behaviour on your device?
Best Regards,
Mike
07-02-2010 09:29 AM
Michael,
Kevin
07-02-2010 03:48 PM
Kevin:
Thank you for investing your time, on our issue. It is very much appreciated.
Best Regards,
Mike
