How to change password on ASA5510
Answered Question
May 20th, 2010
How to change password on ASA5510. Thanks..
Correct Answer by Jennifer Halim about 6 years 4 months ago
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 05/20/2010 - 13:17
The command references are the things to use when you need to know the syntax for a command -
ASA 8.2 command reference
note you only specify the "encrypted" keyword if the password you are entering is already encrypted ie. not clear text so you probably don't need it. See the command reference for full details.
lawsuites Mon, 05/31/2010 - 19:37
thanks, we already have password to login and enable the # mode.  Since so many people have this password in the office so i would like to change it so less people have access to firewall setting.
I want to change both the login and enable mode passwords
