05-20-2010 01:33 PM - edited 02-21-2020 03:58 AM
Can the managment port have its own gateway address? My computer is on vlan A and the mgnt port is on network B. ospf has populated the routing table for the asa to use the inside interface for vlan A. But when i try to ping the address on B the asa does not know how to get back, only in mgnt port but route table show a path out the inside interface.
I am having this same problem on both an ASA and the 3750.
05-20-2010 03:23 PM
The ASA has one routing table only. So the management interface is sharing the GW that you have on the ASA along with the rest.
ON the router you can use vrfs per interface so you can have multiple routing tables.
I hope it answers the question.
PK
05-20-2010 03:47 PM
any susgestions on what i am trying to do?
can traffic enter the mgnt interface and come out the inside?
05-20-2010 04:00 PM
Unfortunately, the ASA will not allow it.
The only thing you can do is tranlate the host so it looks different to the ASA.
PK
