Cisco IOS PPTP Vpn traffic issue
May 20th, 2010
I seem to be having a problem with one of our newer routers and utilizing PPTP.
The problem is that while the sessions connect fine, none of the traffic can route. It seems to work for about the first 3-5 seconds and then seems to drop all traffic while however staying connected.
The router is a 2811 ios version Advanced IP 12.4-9 T7
The config relating to pptp:
aaa new-model
aaa authentication login webvpn local
aaa authentication ppp default local
aaa authorization network default if-authenticated
aaa session-id common
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
  protocol pptp
  virtual-template 1
interface Virtual-Template1
ip unnumbered FastEthernet0/0
ip mroute-cache
peer default ip address pool DIAL-IN
ppp encrypt mppe auto required
ppp authentication ms-chap ms-chap-v2
ip local pool DIAL-IN
Can someone help me debug .. i read somewhere it could be something related to "flow control alarm"
Please let me know
1 vote
Loading. Thu, 05/20/2010 - 13:52
To add when i perform a:
show vpdn session all
%No active L2F tunnels
%No active L2TP tunnels
PPTP Session Information Total tunnels 1 sessions 1
Call id 154 is up on tunnel id 160
Remote tunnel name is
  Internet Address is
  Session username is xxxxx, state is estabd
    Time since change 00:26:36, interface Vi4
    Remote call id is 32768
    177 packets sent, 340 received, 3575 bytes sent, 18051 received
    Last clearing of "show vpdn" counters never
      Ss 178, Sr 359, Remote Nr 177, peer RWS 64
      10 out of order packets
      Flow alarm is set.
  Unique ID is 155
Related Content
