error sip
May 20th, 2010
Hi, anyone know why occurs this error in SIP.
000849: May 20 18:37:25.210: //-1/xxxxxxxxxxxx/SIP/Error/rtpAvpCodec_to_voipCodec:
Unexpected RTP PayloadType :255 in SDP Body
000850: May 20 18:37:25.214:
//11673/91C0E3929CC3/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
//11672/91035E3E9CBD/SIP/Error/sipSPICompareVersionSessionId:
Check old and new values of session id and/or version id in SDP
__________________________--
To: <sip:[email protected]:5060;transport=udp>
From: 2272106 <sip:[email protected]:5060>;tag=ds83d26857
Call-ID: [email protected]
CSeq: 1 INVITE
Content-Length: 247
Contact: <sip:[email protected]:5060;transport=udp>
Expires: 10
User-Agent: Cisco-SIP-CVP/7.x
App-Info: <10.6.20.202:8000:8443>;ringtone=ringback.wav
Call-Info: <sip:10.125.1.254:5060>;purpose=x-cisco-origIP
Remote-Party-ID: <sip:[email protected]>;party=calling;screen=no;privacy=off
Date: Thu, 20 May 2010 18:37:23 GMT
Supported: timer
Supported: resource-priority
Supported: replaces
Min-SE: 1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO,
REGISTER
Allow-Events: kpml, telephone-event
Content-Disposition: session;handling=required
Cisco-Gucid: 91035E3E637511DF9CBDC57342836117
Content-Type: application/sdp
v=0
o=CiscoSystemsSIP-GW-UserAgent 7979 3286 IN IP4 10.125.1.254
s=SIP Call
c=IN IP4 10.125.1.254
t=0 0
m=audio 17894 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
000851: May 20 18:37:25.230: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.6.20.202:5060;branch=z9hG4bKaYTXegojVndYbZTzLVQJuw~~108190
Date: Thu, 20 May 2010 18:37:25 GMT
CSeq: 1 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
000852: May 20 18:37:25.230: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: <sip:[email protected]:5060;transport=udp>;tag=107086E4-C54
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
000853: May 20 18:37:25.362: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:[email protected]:5060;transport=udp SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
000854: May 20 18:37:26.420: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 10.6.20.202:5060;branch=z9hG4bKaYTXegojVndYbZTzLVQJuw~~108192
Max-Forwards: 70
To: <sip:[email protected]>;tag=10708204-1FF8
CSeq: 1 INVITE
Content-Length: 209
Contact: <sip:10.6.20.202:5060;transport=udp>
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 10.6.20.205
s=SIP Call
c=IN IP4 10.6.5.106
t=0 0
m=audio 24654 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
000855: May 20 18:37:26.424: //11672/91035E3E9CBD/SIP/Error/sipSPIProcessCallInfoHeader:
Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
000856: May 20 18:37:26.424: //11672/91035E3E9CBD/SIP/Error/sipSPICompareVersionSessionId:
000857: May 20 18:37:26.432: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 20 May 2010 18:37:26 GMT
CSeq: 1 INVITE
Content-Length: 0
Abu Hadee Thu, 05/20/2010 - 16:00
  • Silver, 250 points or more
Can you send  me voice gateway and version to me? Also, if possible collect "debug ccsip all", do not use this debug if you have live call. Just for test call only. Also, put the log into buffer or syslog , then collect
- abu
auppal Fri, 05/21/2010 - 16:06
  • Cisco Employee,
404 means that req-uri doesnt have a valid match on the ios. You can confirm by using sh dialplan num
on the req-uri
