Network Backbone
May 20th, 2010
I am in the preocess of re-designing my network topology (i.e. routers and switches).  Can anyone tell me where I can find informaton on the best way to do this?
Ganesh Hariharan Thu, 05/20/2010 - 23:19
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the below link hope to help !!
http://pages.csam.montclair.edu/~robila/SECURITY/S2007_P/P2/Final%20Paper.pdf
Ganesh.H
If helpful do rate the post
dacruzer1 Fri, 05/21/2010 - 11:29
Thanks for replying back but I guess I do not have enough entitlements to access the website:
Forbidden File or Application
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
If you feel you have reached this page in error, please try one of the following methods to locate your document:
  1. If you are manually entering the URL into your browser location bar, be sure to include the file name of the page you are trying to access (file names typically end in .htm, .html or .shtml).
  2. Use the Search feature located in the upper right section of this page.
  3. Return to the Cisco.com Home or select a primary site area from the top navigation bar.
  4. Consult with your Cisco Account Manager to confirm you have the appropriate entitlement to access this page.
If you would like to contact someone about this problem, please click on the Contacts & Feedback link below.
