05-20-2010 05:27 PM - edited 03-06-2019 11:11 AM
Hi every body
I just want to know what method shitches use by default to forward frames. Is it fragment- free or store and forward or cut-through ?
thanks and have a good day.
Solved! Go to Solution.
05-20-2010 05:31 PM
sarahr202 wrote:
Hi every body
Sarah
All Catalyst switches use store and forward except the Nexus switches which i believe use cut-through for reduced latency.
Jon
05-20-2010 09:58 PM
Hi every body
Store and forward method is the default which means a switch buffers and, typically, performs a checksum on each frame before forwarding it on to ports.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
05-20-2010 05:31 PM
sarahr202 wrote:
Hi every body
Sarah
Jon
05-20-2010 09:58 PM
Hi every body
Hope to Help !!
Ganesh.H
