NAT no outside world
May 20th, 2010
I have configured NAT on the router and can ping all the way to the cable modem from a laptop through the 2621xm, but I cannot get the internet.  I am posting the configs.  Can anyone see where I have missed something? This is a cable modem and a static IP from the ISP.  Thanks
Current configuration : 1086 bytes
version 12.3
hostname C3PO
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip audit po max-events 100
username xxxxxxxx privilege 15 secret 5 $1$Knq9$mitrdQL12pdt3dm9/jhb41
interface FastEthernet0/0
ip address 173.160.184.61 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.99 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat inside source list 1 interface FastEthernet0/0 overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 173.160.184.62
access-list 1 permit 10.0.0.0 0.0.0.255
banner login ^C What the xxxx are you doing here! ^C
line con 0
logging synchronous
speed 115200
line aux 0
line vty 0 4
password xxxxx
login local
history size 256
transport input telnet
end
Jennifer Halim Thu, 05/20/2010 - 22:46
  • Cisco Employee,
If you can ping all the way to the cable modem, that means that the NAT is working. Can you ping out to the internet?
for example: ping 4.2.2.2
Is DNS resolution working? Maybe it's dns server that has not been configured on the internal LAN yet.
You can check "show ip nat translation" to see if NAT is working when you try to browse the internet OR ping a host on the internet (4.2.2.2).
mauser_delgadillo Wed, 12/15/2010 - 14:45
Your need a IP DHCP and DEFAULT-ROUTER. Do you owen a static ip add?.
Ex:
ip dhcp pool name of the pool
default-router your 10.0.0.99 255.255.255.0
mauser_delgadillo Wed, 12/15/2010 - 14:46
Your need a IP DHCP and DEFAULT-ROUTER. Do you have a static ip add ?.
Ex:
Related Content
