Dialing L2TP from Router
Hello friends!
i have a query.. i have a strongvpn acount which i can dial easily from my PC using either PPPTP or L2TP/IPsec VPN dialer.... But my requirement is to dial it from a CPE Router i have got. (837/2811)
is there any possibility to do this???? can someone share sample configuration or document required to achieve this.
Ganesh Hariharan Fri, 05/21/2010 - 00:59
Hello friends!
Check out th e below link hope to help !!
http://au.billion.com/downloads/VPN-L2TP%20FAQ.pdf
Ganesh.H
jaesposito Mon, 07/18/2011 - 18:48
Asad747,
Were you successful in getting your Cisco router configured via L2TP to StrongVPN?  I have a 881W running 15.1 and would love to do just what you described above.  But, I wanted to find a Cisco user that was successful before I signed up for StrongVPN.com.
Please do share your experience.  Thanks!!
James E
Asad Ul Islam Mon, 07/18/2011 - 21:33
Hello James,
Unfortunately i was not able to succeed in Dialing L2TP from Cisco Router, altough in newer IOS documentations this feature is claimed to be supported. but i never managed to get it worked.
In the end i had to buy a small linksys router supporting opensouce image DD-WRT which has both L2TP and PPPTP clients present in it.. and it worked beautifully with strong VPN.
Asad
