mib to catalyst 2960
Answered Question
May 20th, 2010
I want to copy (install) mibs to a cisco catalyst 2960 switch.
I don't know how can I do that.
I want this tables read: vlanTable,dot1dTpFdbTable,dot1dBasePortTable,ifXTable
I need install this two mibs: BRIDGE-MIB, CISCO-STACK-MIB
I know the cisco switch haves a mibs load order, but I dont know how can install a mib to a switch.
Sorry for my english.
Thx.
Correct Answer by Collin Clark about 6 years 9 months ago
The MIBs get installed on your Network Management Station, not on the switch. The switch already has the OIDs in the IOS.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Fri, 05/21/2010 - 05:03
szabotamas Fri, 05/21/2010 - 07:01
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normál táblázat"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Thx for the replay, then I must find a way to install Cisco mibs an OpenSUSE box.
