WAE Report Time
May 21st, 2010
i have a Problem with the Time in alle default Reports on the Central Manager.
The time from alle Reports is wrong.
The time on all WAE Device are right. I can make a show clock. So i get the right time.
Can I Change the Default Time in all Reports for all Admins on the Central Manager?
Version is 4.1.5f
Andreas
Zach Seils Fri, 05/21/2010 - 10:23
  • Cisco Employee,
Andreas,
Do you have the time set correctly on the Central Manager device itself?  Do you have any time sync alarms for the devices being managed by the CM?
Note that the default setting for reports in the CM is to use UTC time.  You can change this in the report settings to make the reports use the CM time (aka CDM Local Time).
Zach
Andreas_Seybold... Tue, 05/25/2010 - 06:01
Hi Zach,
thanks for your Answer,
I have set the correctly time in the Central Manger and in all other WAE´s. I can see the correct time with "show clock" on all Devices.
We use also a NTP server.
I can with my Admin Account change the time from all Reports. That is not a Problem and works fine. But the Other Admin´s on the Central Manager can see my changed Time.
Is that Possible with a "Master" Admin change the Time and all other Admins can see the correct Time ?
Thanks for your help
Andreas
