ASA: what are the TCP ports to be permitted for microsoft AD/Exchange/IIS?
May 21st, 2010
Dear all,
I need to configure a access rule in ASA 5550 to permit microsoft AD/Exchange/IIS services, anyone has the idea what TCP/UDP ports to be opened?
Like other firewall they have predifined services object for these MS services, so is there any other way to configure the ASA to permit such services, for instance, use predefined objects if it has...
Marcin Latosiewicz Fri, 05/21/2010 - 02:30
Most of this information can be found on microsoft's excellent knowledgebase pages (IF not part of well known services -> check /etc/services on most unix systes)
If in doubt, best to see what ASA is blocking, enable logging to buffer on informational level:
logging time
logging buffer-size 1040000
logging buffere info
Following this you can do:
show logg | i Deny
show logg | i $IP.ADD.RE.SS
To see what is being denied :]
