Looking for a CISCO model
May 21st, 2010
Hi all,
I'm looking for a model.
Looking to do NAT between two networks.
I must have a total of 6 gigabits interfaces.
I think I need a model 1900 series (router) with an extra card (4 ports at gigabit)
Can you advise me on a model?
A router is required to do NAT?
Thank you for helps
Ganesh Hariharan Fri, 05/21/2010 - 02:46
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi all,
Thank you for helps
Check out the below link on 1900 series routers with cisco ether switchh module
http://ciscosystems.com/en/US/docs/routers/access/1900/software/configuration/guideswitching_ps10538_TSD_Products_Configuration_Guide_Chapter.html#wp1076006
Hope to help !!
Ganesh.H
paolo bevilacqua Fri, 05/21/2010 - 03:05
  • Hall of Fame,
    Founding Member
I think you are the end user ?
Please select first a reputable consultant, or certified Cisco partner to help you design and implement your network,.
Do not try to do it yourself, as that usually results in costly mistakes.
