C2821 package process
May 21st, 2010
Hi Netpros:
I have C2821 to use EoSDH link on fix GE port , I concern that dose it process real 1000M traffic when running routing protocol and Mpls etc..
thru it's line speed forward in documentation.
thanks
Herman
paolo bevilacqua Fri, 05/21/2010 - 03:27
  • Hall of Fame,
    Founding Member
Search "router performance" and you will finf many posts with a document.
However in short, the 2821 cannot to gigabit wire rate and not even an half of it.
jj-zhou Fri, 05/21/2010 - 06:28
HI :
thanks fast response , but may I have a practice value or exact test result to refer , less than 500M , it means based 1500Byte or what's testing environment.
thanks
Herman
paolo bevilacqua Fri, 05/21/2010 - 10:42
  • Hall of Fame,
    Founding Member
Serarch the document here and has all the info in there.
