Jumbo frame & link aggregation
mumeer
Is it possible to do link aggregation after enabling jumbo frame.
Mudassir
Ganesh Hariharan
Mudassir
Hi Mudassir,
Jumbo frames can be enabled on interfaces configured for port-channel protocols. The following are some of the guidelines or restrictions:
    *      All the ports in a port-channel must have the same MTU.
    *      Changing the MTU of a port-channel interface changes the MTU of all member ports.
    *      If the MTU of a member port cannot be changed to the new value due to the member port being the blocking port, the port-channel is suspended .   *      A port cannot join a port-channel if it has a different MTU than the others in the existing port-channel.
    *      If an individual member port's MTU is changed, the port is suspended.
Check out the below link for more information
http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Ganesh Hariharan
Mudassir
Hi Mudassir,
Hope to Help !!
Ganesh.H
