CME no PRI card using AS5300 GW - HELP
May 21st, 2010
HI,
I have a CME installed on a router with NO pri card. I have this connected to a AS5300 GW, which is currently working for voip on another PBX. I have configured the CME and can make outbound calls ok, but i cannot get the main number to connect to the extensions. I have debuged the CME router (debug ccsip) and i get 404 - not found. I need to know how to point this incoming number to the CME extensions. When i do a sh dial-peer voice sum, it shows POTS ports on the CME ???? i need to get the main PRI number to point to the reception extension.
anyine don ethis before ? if so any ideas on how i get this number to point at the CME extensions ?
thanks
Paolo Bevilacqua Fri, 05/21/2010 - 10:40
  • Hall of Fame,
    Founding Member
That means the number has no match. Likely you will a translation or secondary number on the CME router.
