CUPS without AD for testing?
May 21st, 2010
  • Silver, 250 points or more
I`m installing CUPS 7 as a test without  AD integrating into CUCM, I have working with simple phone calls, If I go off hook on my own phone it is replicated to the CUPS Client
Do I need AD to get Presence to work? I thought you could manually add a contact if you kept the ID the same as in CUCM so to observe their presence, status?
Can you "pickup " a call form a user you are monitoring?
thanks
William Bell Fri, 05/21/2010 - 05:30
  • Purple, 4500 points or more
No, you do not need AD to get presence between CUCM and CUPS to work.
thanks
I don't follow. Do you mean emulating the "call pickup" feature?  I think you would need to configure "call pickup" groups as you would normally.  But maybe you had another feature/use case in mind.
HTH.
Bill
iptuser55 Fri, 05/21/2010 - 06:40
Bil,
I`ve got it working by adding a user via the  CUPS User page however I have another question
  • Only a user who I have configured as a CUPS user shows presence - is this correct? I thought that as well as the Subscribe CSS on my phone can see the other DN then you should see the status of the DN  on my client even if they are not a "CUPS" user? or is hti sdue to the lack of AD
  • Can you see a ringing DN, the idea is that from my CUPS client I can see the status of a monitored DN - ringing and as on your reply make use of the Call Pick Up feature
thanks
Jonathan Schulenberg Wed, 05/26/2010 - 08:55
  • Cisco Designated VIP,
    2017 IP Telephony
this correct?
Correct. The end user must be assigned the CUPS capability for any CUPS-related functionality to work for them, including the ability of others to watch their status.
Incorrect. The Subscribe CSS is used only within UCM for presence indication on BLF buttons and XML directories.
No. UCM will only show send a PUBLISH when the line appearence is in use, not alerting. There is no call pickup functionality available in the CUPC 7.x client. You would need to use the PickUp soft key on your phone.
