05-21-2010 05:34 AM - edited 03-06-2019 11:12 AM
Cisco Call Manager setup.
Cisco 3560-G has the call manager and Unity. Off of this (one of the fiber GBIC ports) is a 3560 switch. What I need to do is hang another 3560 off of this second 3560 and run a couple of phones off of it (I may get one of the smaller 8 port 3560s for this). Do you see any problems with this?
Thanks.
05-21-2010 07:04 AM
No problems. I have a site that have several 3560s that run fine. As long as you're passing your vlans correctly, everything should be good.
HTH,
John
05-21-2010 07:05 AM
Thanks.
No you should be fine if you daisy chain the switches. It's not best pratice in terms of design generally but there shouldn't be a problem. I'm assuming it will look something liek -
Call manager -> 3560G -> 3560 -> 3560
Jon
