05-21-2010 05:37 AM - edited 03-19-2019 12:58 AM
Hello Guys,
I discovered due some stats that my vg224 analog gateways requests for config file from ccm, though it always failes. After taking a closer look I saw that they use as file name their hostname , e.g. vg224-20.conf.xml . Of course the cm cannot find any file called like this, because the official registration names on cm are called "SKIGW2333XXXXXX" . I do not really want to use as hostname such needles names, is there any command to force the VGs to use this SKIGW mac adress combination for config request?
For normale Voice Gateways I always have the option to adjust the hostname :-/ within CM.
Thanks and Cheers
Solved! Go to Solution.
05-24-2010 09:51 AM
Is it possible that you could post the config of your VG224?
You state that in CUCM the vg224 port names start with SKIGW which would indicate to me that you are attempting to use SCCP for communication between CUCM and the VG224. However, you also state that you are seeing the VG224 request a configuration file with the hostname (vg224-20.conf.xml) which would indicate to me that the VG224 is for some reason trying to communicate using MGCP. If you could post your config, we can probably get to the bottom of this.
Adam
Please rate if helpful
05-24-2010 09:51 AM
Adam
05-25-2010 11:09 PM
Hello Adam,
thanks for encouragement to help me.
I guess you are totally right with your mgcp assumption. Let me show you a cut out of the vg config:
stcapp ccm-group 1
stcapp
voice-card 0
voice service voip
modem passthrough nse codec g711ulaw
caller-id enable
voice-port 2/21
cptone DE
caller-id enable
voice-port 2/22
cptone DE
caller-id enable
voice-port 2/23
cptone DE
caller-id enable
ccm-manager redundant-host xxx.xxx.xxx.xx
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server xxx.xxx.xxx.xxx
ccm-manager config
mgcp modem passthrough voip redundancy
sccp local FastEthernet0/0
sccp ccm XXX.XXX.XXX.XXX identifier 1
sccp ccm XXX.XXX.XXX.XXX identifier 2
sccp ccm XXX.XXX.XXX.XXX identifier 3
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
According to the issue I can completely remove the ccm-manager part, 'cause callmanager communicate by sccp with them, right? (I re-checked that)
06-02-2010 10:48 PM
I removed the unnecessary mgcp config and logs are fine now.
