How to reset user name for 3825 router?
May 21st, 2010
I just got a new cisco 3825 router and logged in to it via username: cisco (one time use only).  However, before I change the username, I rebooted router, then I can't log in.  How can I reset the user name to login?
Giuseppe Larosa Fri, 05/21/2010 - 08:06
  • Hall of Fame,
    Founding Member
Hello Mcmillansc,
if the device is configured for asking a username / password for example with login local under line vty 0 4 (telnet/ssh sessions ) or under con 0 ( console) and no username password pair is configured your only option is is to perfom password recovery procedure.
During the password recovery procedure there is one step that configure the config register in order to ignore configuration file at next reboot.
Password recovery procedure for C3825 can be found here:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
and more specifically:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_password_recovery09186a0080094774.shtml
follow the procedure carefully you need a console cable, hyperterminal and an Rs-232 DB9 port on your PC or an USB to RS232 converter
Hope to help
Giuseppe
Ganesh Hariharan Fri, 05/21/2010 - 23:19
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the below link fo rstep by step procedure to reset the password on 3800 series routers
http://www.cisco.com/en/US/products/hw/routers/ps274/products_password_recovery09186a0080094774.shtml.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
