ā05-21-2010 07:05 AM - edited ā03-06-2019 11:12 AM
Is there any known compatability issue/problem on the Cat2950G-24-EI with an onboard SUN NIC card V890, QuadGigaswift PCI-X R Ethernet (QGE-X) OS version: Solaries 10.
This card can not communicate at 100MB full duplex. it defaults to 100/Half duplex.
kgabo
ā05-21-2010 07:07 AM
kgabo
kgabo
How are the port and NIC configured ie.
either configure both for auto-negotiation or configure both for 100 full duplex but you can't configure one for 100 full and leave the other to auto-negotiate.
Jon
ā05-21-2010 10:42 AM
kgabo
Hi Kgabo,
There is no issue with port of 2960 and NIC as suggested configure either in auto/aoto or hardcode maunal setting at both ends and share the results.
Ganesh.H
ā05-21-2010 12:42 PM
Sounds like the sun nic was hardcoded to 100/full which would then put
the switch in 100/half if it set as auto/auto which is a normal state .
Either hardcode the switchport to 100/full or set the sun nic to auto/auto .
