05-21-2010 07:13 AM - edited 03-06-2019 11:12 AM
WHich is the best IOS upgrade on the c3550 running IOS ver c3550-i5q3l2-mz.121-22.EA10b.bin?
05-21-2010 10:10 AM
Check out the below link for ios upgrade procedure for 3550 switches
and with your network environment with having in mind about the application perfromance,lots of featuire differe from ios to ios.so i would suggest if you dont face any problem with existing one don't go for upgrade if it is necessary.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
05-22-2010 05:48 AM
IOS version 12.1 is pretty old. I'd go for the 12.2.
