CUVA works intermittently with IP phones 7940 and 7960 on version 8.1.2 SCCP
May 21st, 2010
I have an issue working with the connection between certain Cisco IP phones 7940 and 7960 which works with firmware version cmterm-7940-7960-sccp.8-1-2.cop.sgn.
The problem is that when I connect my PC in data vlan and the phone using the phone PC connection the CAST protocol is not constantly connecting at the CUVA application. The CUVA version is
If I test using the same switch port and the same PC but another video enabled phone. then the connection is stablished properly and consistently.
I can send you the CUVA problem report in one of the cases If you needed.
Thanks in advance,
