difference between Total output drop and Queue Output drop
May 21st, 2010
Who know what is difference between both values and when counters are increment.
show interface gig0/1
Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/26/0 (size/max/drops/flushes); Total output drops: 151329
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
I read most documentations and troubleshootings (for example "In/Out queue drop", "buffer tuning") but there is poorly description.
Tom
Ganesh Hariharan Fri, 05/21/2010 - 10:16
Tom
Hi Tom,
Output drops are the result of a congested interface (for example, the traffic rate on the outgoing interface can't accept all packets that should be sent out). The ultimate solution to resolve the problem is to increase the line speed.
Check out the below link for more information
http://www.frameip.com/dos-cisco/queue_drops.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
jsmetz Fri, 12/17/2010 - 03:33
Hi Tom,
Better later than never
Total ouput drops is the sum of qdrops from 'show hqf interface' for latest IOS releases which include HQF framework (QoS Code Rewrite) starting with 12.4(20)T.
qdrops increase for a class when we have more packets than the queue-limit (available buffer in show hqf int) for the given class.
Output queue drops is the sum of qdrops + drops due to other features such as WRED, etc .
Cheers,
Jean
Tomasz Tuzimek Sun, 12/19/2010 - 10:16
########################for  CBWFQ
sh int gi 0/1
GigabitEthernet0/1 is up, line protocol is up
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 (sum hard-limit and soft-limit and other features)
  Output queue: 0/1000/64/0 (size/max total(#hard-limit)/threshold(soft limits are set per queue so I don't know what is this? )/drops(only hard-limit drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 3/3 (allocated/max allocated)
     Available Bandwidth 34984 kilobits/sec
I think that "Output queue" drops in "sh int gi 0/1" is the hard limit (hold-queue - default 1000 packets  per interface)
The soft limit(queue-limit - default 64 packets per queue) is in the "sh policy-map interface gi0/1":
Class-map: NC (match-any)
      986 packets, 126198 bytes
      5 minute offered rate 1000 bps, drop rate 0 bps
      Match: ip precedence 6
        5 minute rate 1000 bps
      Match: ip precedence 7
        0 packets, 0 bytes
        5 minute rate 0 bps
      Queueing
        Output Queue: Conversation 265
        Bandwidth 16 (kbps)Max Threshold 64 (packets)
        (pkts matched/bytes matched) 193/54748
        (depth/total drops/no-buffer drops) 0/0/0    #soft limit (queue-limit)  queue NC
Hold-queue(default1000) is hard limit (sum of all packets in all queues on interface) if sum packets on all queues of interface exceed hold-queue the interface will drop packets above that limit.
