Auto MDI Issue
May 21st, 2010
I have one 4506E with sup card cp-wx45-sup6l-e and line card wx4648e running IOS version 12.2 (53) sg2. Other end is connected to 2950, IOS 2.1`(22).
Auto MDI is enabled on line card wx4648e with auto duplex & speed on. But operational status of the port is going down when I am connecting with a straight cable. With crossover cable it is working fine.
Waiting for urgent reply.
Thanks & Regards
Ganesh Hariharan Fri, 05/21/2010 - 10:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thanks & Regards
Cisco 2950  don't support auto-mdi/mdix, so i would suggest to begin with  the correct cable.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
pradip.saha Fri, 05/21/2010 - 11:19
Hi Ganesh,
This is not the actual issue.
Actual issue is POE line cards does not work with auto mdi enabled. So, we have disabled power-line in interface config mode to get the issue resolved.
Thanks & Regards
Leo Laohoo Sat, 05/22/2010 - 06:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hold on.  What do you mean by "speed on"?  Auto MDI/MDI-X works if speed and duplex are set to AUTO.  If either one is hard-coded then auto-mdix is disabled.
