05-21-2010 11:05 AM - edited 03-21-2019 02:36 AM
For the UC500, is there an option of setting up a VPN type phone that can connect back to the UC500 over the Internet without having to have a VPN router or firewall initiate a VPN back to the UC?
For example, Avaya 9600 VPN phones have the ability to do that. Thanks.
05-21-2010 11:28 AM
05-21-2010 01:20 PM
This is exactly what I'm looking for, thank you.
I'm following the instructions, but I'm stuck on installing SSL Client. I get "Error in copying package file....." I attached a picture of the error.
I tried installing these 2 packages; get same error:
anyconnect-win-2.5.0217-k9
anyconnect-win-2.4.1012-k9
Any ideas?
05-21-2010 02:20 PM
I figured it out. Since I have a different IP for the UC540, I was not able to reach the 10.1.10.0/30 Network. I added a route on my PC, and now I'm good. SSL installed correctly.
Now I launch the wizard and I get a new error: Error null: There are at least 1 SPA 525G Phone not reachable, but there definitely is one reachable. I rebooted the phone and same error.
05-21-2010 02:33 PM
I've seen that too. Rediscover topology in cca and retry please.
Steve DiStefano
Systems Engineer
Small Business Sales
Cisco Systems Inc.
Research Triangle Park
North Carolina, U.S.A
1.919.392.6219
www.cisco.com/smb
05-21-2010 02:41 PM
Stupid question, but I don't see a specific option to "rediscover topology". Can you show me where that is? Thanks.
05-21-2010 02:44 PM
Figured it out, same fix as the first one with the local route needed on my PC, need to be able to access the phone on the 10.1.1.0/24 network.
05-21-2010 02:46 PM
Dual nic is something we should avoid with cca, since it also needs to
route to 10.1.10.0/24 as well or cue configs won't make it down. Be
careful. Disable wireless nic when using cca.
Steve DiStefano
Systems Engineer
Cisco Systems Inc.
1.919.392.6219
www.cisco.com/smb
05-21-2010 02:44 PM
It's on the top toolbar of cca window... Two green refresh arrows in a
single icon.
Steve DiStefano
Systems Engineer
Cisco Systems Inc.
1.919.392.6219
www.cisco.com/smb
07-29-2010 07:08 PM
is this the only 500 series ip phone that can connect via vpn? can the 7900 series phones (7942 or 7962) do this as well?
07-29-2010 07:26 PM
Only SPA525 today is supported.
Steve DiStefano
Technology Solutions Architect - Sales
Cisco Systems
1.919.392.6219
www.cisco.com/smb
On Jul 29, 2010, at 10:09 PM, "robray_sc"
07-29-2010 10:39 PM
Rob - Here's another thread that provides just a little more info about the 79xx SSL support for UC500.
