SA500 series & QuickVPN / EasyVPN / etc
May 21st, 2010
How is it with regards to Cisco Small Business security appliances using different VPN clients - such as the QuickVPN or Easy VPN - or any other VPN clients?
What about the RV units - and how does it work with regards to ASA5505/5510 - can any VPN client be used?
Do we have any documentation / whitepaper as to how this works?
rshao Fri, 05/28/2010 - 00:20
SA500 offically supports Quick VPN client. It doesn't support Cisco EzVPN
There are also 3rd party VPN clients that are known working with SA500, such as ShrewSoft.
Here is a doc.  https://supportforums.cisco.com/docs/DOC-9378
For SA500 VPN configuration, it can be found in "VPN Configurating" section in the Admin guilde.
RV should also support Quick VPN client.
Cheers,
Richard
