Load Balancing ASA question - which IP do I direct clients too?
Answered Question
May 21st, 2010
I have 2 5520's with a 50 user SSLVPN license on each. I want to use the VPN load balancing feature. Should I be sending users to the Cluster IP Address ? The documentation isnt clear on this point.
Justin
Correct Answer by Jon Marshall about 7 years 2 months ago
Justin
Justin
You need to use the cluster IP address. If you used the actual address of the firewall outside interfaces then you wouldn't get load-balancing.
Jon
Correct Answer by hdashnau about 7 years 2 months ago
That's correct. You should have the VPN connect to the LB cluster IP, not the individual IP addresses. The master ASA will listen for the connection requests to the LB Cluster IP and based on load either accept the connection or automatically redirect it to one of the standby ASAs in the cluster. This should all be transparent to the VPN user connecting.
Overall Rating: 4 (4 ratings)
Correct Answer
hdashnau Fri, 05/21/2010 - 12:28
  • Cisco Employee,
Correct Answer
Jon Marshall Fri, 05/21/2010 - 12:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Justin
Justin
Jon
Jon Marshall Fri, 05/21/2010 - 12:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Out of interest, why was this rated as not helpful ?
Jon
