IP Communicator using PPTP
May 21st, 2010
I have a UC520 using Cisco VPN Client and PPTP. The Cisco IP Communicator phone works great when using the Cisco VPN Client connection the phone will register, but when using PPTP connection the phone will not register. I have posted my configuration and would like to know what I'm missing for the PPTP connection for the IP Communicator softphone to register. Thanks.
Abu Hadee Tue, 05/25/2010 - 03:50
It looks like your access-list 103 is causing the problem. When you had PPTP enabled, can you trying pinging the GWs following ip address
192.168.10.1
192.168.100.1
I didn't see the dhcp pool "test" either. How your pc getting IP address?
Trying removing access-list 103 from the vlan10
let me know how it goes
Thank you
- abu
lyle.stevens Tue, 05/25/2010 - 06:42
My test pool is there in the range of 192.168.10.221 to 240. I can ping 192.168.10.1 but not 192.168.100.1. I removed the access-list 103 from vlan 10 and still have the same result of the IP Communicator phone not registering.
