CDP not working for most switches in WCS 6
Running WCS 6 and WLC's at 6, wcs does not show cdp neighbours for the access points except on two access points (see attached image).
One of the access points is a lwapp and the other is autonomous.  If I telnet to the switch and look at the cdp neighbours it does show me neighbours.       I have looked at the switch configs and do not see anything really different between a switch that is working and one that is not.  Any ideas?
Also Switch Port Tracing does not work for me, perhaps this is because of the same problem?
tkhan Wed, 06/02/2010 - 11:13
Make sure your switchports are void of any trunking commands.  I had this issue before and realized that during the migration from IOS to LWAPP, a "switchport trunk encap dot1q" command was left on the ports by the guys doing the migration.  Once I removed it, CDP started working on WCS views.
sschmidt Wed, 06/02/2010 - 11:15
That was indeed the issue.  We worked on this in a TAC case.  Good call.
Related Content
Trending Topics - Security & Network
