Call routing issue...call manager 7.0
May 22nd, 2010
Dear All,  I am facing the following two issues.  1. I am using call manager 7.0 and router 2811 with 4 ports fxo card. Four telephone lines are terminted in fxo card. When I dial a number my two ports go off-hook permanently even i disconnect the call. After that I don't be able to make the call on all four numbers. I only could be able to dial on two numbers. Once i removed the cable from port and reconnect it than i will be able to do call on all four numbers.  Telephone lines number are UAN:111111532 99262397 99262398 99262399 99262400 2. Call is not transfering properly to IP phone extension #1003. Whereas on other three number it's transfering properly. Configuration are same on each phone device at Call Manger.   OUTPUT results:  LHR-LDA-JT-DC-RTR#sh voice port summary                                           IN       OUT PORT           CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC ============== == ============ ===== ==== ======== ======== == 0/1/0          --  fxo-ls      up    dorm idle     on-hook  y 0/1/1          --  fxo-ls      up    up   idle     off-hook y 0/1/2          --  fxo-ls      up    up   idle     off-hook y 0/1/3          --  fxo-ls      up    dorm idle     on-hook  y  PWR FAILOVER PORT        PSTN FAILOVER PORT =================        ==================  Configuration:  voice class h323 1  --More--                            h225 timeout tcp establish 3  !  voice-port 0/1/0  cptone PK  timeouts call-disconnect 5  timeouts wait-release 5  connection plar 1000  caller-id enable ! voice-port 0/1/1  --More--                            cptone PK  timeouts call-disconnect 5  timeouts wait-release 5  connection plar 1001  caller-id enable ! voice-port 0/1/2  cptone PK  timeouts call-disconnect 5  timeouts wait-release 5  connection plar 1002  caller-id enable ! voice-port 0/1/3  cptone PK  timeouts call-disconnect 5  timeouts wait-release 5  connection plar 1003  caller-id enable ! ! ! !  --More--                           ! dial-peer voice 10 pots  destination-pattern .T  port 0/1/0 ! dial-peer voice 20 pots  destination-pattern .T  port 0/1/1 ! dial-peer voice 30 pots  destination-pattern .T  port 0/1/2 ! dial-peer voice 40 pots  destination-pattern .T  port 0/1/3 ! dial-peer voice 100 voip  destination-pattern 1...  session target ipv4:192.168.100.1  dtmf-relay h245-alphanumeric !
waqas0612147 Sun, 05/23/2010 - 21:44
Dear All,
UAN #:   111111532
Master#: 99262397
#:       99262398
#:       99262399
#:       99262400
OUTPUT results:  L
IN       OUT
Configuration:
voice class h323 1
voice-port 0/1/0
cptone PK
caller-id enable
voice-port 0/1/1
cptone PK
caller-id enable
voice-port 0/1/2
cptone PK
caller-id enable
voice-port 0/1/3
cptone PK
caller-id enable
--More--
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
Also one telephne line from PSTN to FXO card is dead. And it's terminating in voice-port 0/1/3.
I just rewrite each and everything properly.
Ali
