Callmanager 5.1.1 CDR/CAR problem
May 23rd, 2010
Dear readers,
This is my very first post, so I apologize for any newbie behavior that could show up in this post!
We have a 2 node cluster of Cisco Unified Callmanager 5.1.1 and we have been facing issues with CAR, the problem seems to be the following:
1. At first we were unable to get up to date CAR reports, the only reports that would be available were a month or so old.
2. I tried to troubleshoot the problem at (1.) by increasing the frequency of the CDR load scheduler (which was set to 5 minutes every 24 hrs), while the   uninhabited load should have done the job, but for some reason it didn't.
3. Since then we were able to get constant, up to date CAR reports (this continued for about 40 days), untill one day, no more records were moved to the CAR database, and the latest record that is in the Tbl_Billing_Data is on 19-May-2010, which is the day CDR stopped loading into CAR.
4. I then did a search and followed the instructions in the document published here: https://supportforums.cisco.com/docs/DOC-5706;jsessionid=CBA450FBB6BE86033653746D71B0C5A3.node0 but still, till this day, the latest CAR report is till 19th of May.
5. I used RTMT Trace & Log Query Wizard to view the "Cisco CDR files on Publisher Processed" and files seem to be generated fine.
6. But in the same query I checked the "Cisco CAR Scheduler" logs and what I found is that since 20th of May (the day CDR seemed to fail ) the log was filled with the follwing error, which by looking at the time was generated whenever a CDR Load was triggered:
Trace Level: ERROR
Thread: main
Class Name:  services.Scheduler
Message:  runTasks(): Error while running the task. Will continue with next taskjava.lang.InterruptedException: sleep interrupted at java.lang.Thread.sleep(Native Method) at com.cisco.ccm.car.services.Scheduler.runTasks(Scheduler.java:2087) at com.cisco.ccm.car.services.Scheduler.<init>(Scheduler.java:244) at com.cisco.ccm.car.services.Scheduler.main(Scheduler.java:151)
And honestly I don't have any idea what that error means, but the fact that the error is generated when the scheduled CDR Load starts strongly suggests that this causes our problem.
Please have kind patience and try to help me with this one. I will provide any additional info in case needed!
Rick Arps Thu, 05/27/2010 - 06:04
Have you tried rebooting your publisher?  We have this issue on occasion and an after hours reboot of the pub will free up whatever is
jamming things up.
Hope this helps
Rick
Saladin211 Thu, 05/27/2010 - 23:29
I haven't tried that actually, but a few says back, I googled a lot, and followed many of the troubleshooting advices I found, and seems one of them worked out.
What I think might have solved the problem is increasing the value of the parameter MAX_ERROR_RECORD_ID to a value greater than that of
max(Error_Record_Id) from another table.
It may not be the solution that solved it for me, cause as I said, I did many troubleshooting that night, and I wasn't that patient to verify each action made. And still I would like to find out the root of the problem, cause we don't want to miss records for any other time!
But I'll keep rebooting in mind in case anything showed up again, thanks!
