Deployment configuration!
Jon Marshall Sun, 05/23/2010 - 08:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
[email protected]
Guys
Have a look to the Attached file
how to configure the 4 MBps link on asa-1 to be just dedicated for the server on the dmz and other traffic goes via asa-2 ( link  2 mbps for browsing),project still on the draft,so what is ur suggestion from a to z
Ali
If the firewalls are a pair then configure as active/active and have one context for the server and another context for the inside users.
If the firewalls are standalone simply set the server default-gateway to asa-1 and the internal users to asa-2.
Jon
Ganesh Hariharan Mon, 05/24/2010 - 23:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Jon and Ganesh.H
can 1 firewall with multiple context does the above scenario,e.g context per users and context for the server along with different link from different ISPs
if so how the prospective could be?
JON,congratulation for the gold start beside ur name
thanks
Check out the below link for multiple context configuration as per your requirement with sample examples:-
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml
Hope to help !!
Ganesh.H
