Need Help with port forwarding on pix 501
May 23rd, 2010
Just testing RDP right now and it goes no where.  Not sure which it is either nat or acl that are messed up
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname cisco
domain-name cisco.org
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 4.3.2.1 server1
name 4.3.2.2 server2
name 4.3.2.3 server3
name 1.2.3.5 server4
name 4.3.2.5 server5
object-group network servers
  network-object server1 255.255.255.255
  network-object server2 255.255.255.255
  network-object server3 255.255.255.255
access-list outside_access_in permit tcp host server1 eq 3389 interface outside eq 3389
access-list outside_access_in permit tcp host server2 eq 1433 interface outside eq 1433
access-list outside_access_in permit tcp host server3 eq 1433 interface outside eq 1433
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside 6.7.8.9 255.255.255.192
ip address inside 1.2.3.4 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location server1 255.255.255.255 outside
pdm location server2 255.255.255.255 outside
pdm location server3 255.255.255.255 outside
pdm location server4 255.255.255.255 inside
pdm location server5 255.255.255.255 outside
pdm group servers outside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface outside 1433 server4 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp interface outside 3389 server4 3389 netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 1.2.4.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 1.2.3.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 1.2.3.10-1.2.3.20 inside
dhcpd dns 1.2.4.2 1.2.4.3
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
pciaccio Sun, 05/23/2010 - 16:11
This is just an assumption, however shouldn't your default route point to 1.2.3.1 instead of 1.2.4.1 ??  If your default route is setup wrong you will not get out the door to talk to any external address...
shanetapper Sun, 05/23/2010 - 16:16
thanks for  the follow up i appreciate it.  that may have been my mistyping when trying to change ip addresses.  it has something to do with rdp needing to use something other than 3389.  Graninting access to the all ports to the specific ip address and it works fine.  Now I just need to determine exactly what ports need to be opened up but things are working ok now just not good.
pciaccio Sun, 05/23/2010 - 18:02
The RDP port number is correct.  I would try restructuring your access-list.
You have:
Try it
access-list outside_access_in permit  any host server1 eq 3389
I suggest this because your access-list is applied to the traffic inbound.  This new line will allow anyone to communicate to Server1 only through TCP port 3389...
shanetapper Mon, 05/24/2010 - 04:53
you are correct that would open up to the entire world but that does not resolve the issue.  if i can open up all the ports yet keep it limited to the same handful of ips it is a port issue that is preventing things from getting across....or possibly just one of the random pix nuances
pciaccio Mon, 05/24/2010 - 05:31
You need to be more descriptive in what is happening..
1) Who is initiating the RDP session. Inside svr to outside or outside to inside?  Is the remote svr allowing RDP sessions from your subnet?
2) Are all the svrs seeing the same symptom or just one of them?
3) Did you try chscking the access-lists to see if they are getting any hits on them?
4) Did you try debugging for specific packets and verify that you are natting correctly?
5) Is the RDP session giving you an error?  Did you check the logs off the ASA, Are they providing information about your session?
shanetapper Mon, 05/24/2010 - 05:40
       All outside, yes as stated things are working when opening all ports to the specific ip address
        Only testing on a single server I have control of
         i can look into this
          i did not but believe natting to be correct, do you believe its incorrect based on the above config
          no errors on rdp session just does not connect
Leaving the config as is except for allowing all ports instead of just 3389.  Everything works wonderfully can pull up rdp and connect.
Leaving the config as is with just 3389 rdp does not connect at all.
pciaccio Mon, 05/24/2010 - 05:54
I would then get the global natted outside address of your remote svrs that are
initiating the RDP session. Place them into your access-list
And change the ACL like I suggested earlier but this time place the global outside address on the ACL to be more specific instead of ANY...  This will allow just the specific host(s) that you want in and using only the RDP port...
shanetapper Mon, 05/24/2010 - 06:06
you are confusing me so essentially you are asking me to enter statements like i had on the first go at things
when testing things i had added a second line of
access-list outside_access_in permit tcp host testserver eq 3389 interface outside eq 3389
sorry i am a little lost
pciaccio Mon, 05/24/2010 - 07:35
What did the logs and acl hits tell you??
One thing I would do is change your acl from
to
access-list outside_access_in permit tcp host server1 interface outside eq 3389
access-list outside_access_in permit tcp host server2 interface outside eq 1433
access-list outside_access_in permit tcp host server3 interface outside eq 1433
If that does not work, then I would do a debug ip packet (make sure no other traffic is going through the firewall). then look over all the debugs to see what is happening.  Are these remote servers being natted?  Are you possibly seeing a TCP fragmentation issue where the RDP session never completes?  How do you fail on the RDP session. Does the program open the remote window or are you being prompted with an error immediately?  does the session allow you to log onto it or does it stop you there??
Either way I would stick with the Debugs. thats the best way to determine what and where your issue lies....
cofiguar1 Mon, 05/24/2010 - 15:29
Assuming that you outside IP address is
access-list outside_access_in permit tcp any host 6.7.8.9 eq 3389
static (inside,outside) tcp 6.7.8.9 3389 server4 3389 netmask 255.255.255.255
clear xlate
