05-23-2010 09:12 AM
Dear all,
Please help to find solution for my problem: I can not install VPN client for my computer.
As my system is Windows 7 64 bit, so I downloaded vpnclient-winx64-msi-5.0.07.0290-k9.exe
Extract and run it as Administrator. The welcome message popup, but right after Click on Next, the Fatal Error message show.
My system: Windows 7 Ultimate, run updated with Microsoft. Antivirus is "Microsoft Security Essentials", turn Real time protection Off during this installation.
No any specific software installed. (only M$ Office, Acrobat, Firefox, Chrome.... - wellknown software).
I don't know where to see the log of the instalation. Please let me know if you need any other information.
Thanks for reading and look forward to your reply.
Step 1: Check My system
Step 2: Download vpnclient-winx64-msi-5.0.07.0290-k9.exe, extract it.
Step 3: Run vpnclient_setup.msi as Administrator.
Step 4: Click "Next" and error bellow shown.
Step 5: Googling and see no solution => Ask cisco for help!
05-25-2010 03:21 PM
I've learn how to keep loging of the installation process, bellow is the log.
Please help to tell me what is the problem ?
Thank you.
=== Verbose logging started: 5/25/2010 23:27:56 Build type: SHIP UNICODE 5.00.7600.00 Calling process: C:\Windows\system32\msiexec.exe ===
MSI (c) (84:9C) [23:27:57:018]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (84:9C) [23:27:57:033]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
MSI (c) (84:50) [23:27:57:080]: Resetting cached policy values
MSI (c) (84:50) [23:27:57:111]: Machine policy value 'Debug' is 0
MSI (c) (84:50) [23:27:57:127]: ******* RunEngine:
******* Product: vpnclient_setup.msi
******* Action:
******* CommandLine: **********
MSI (c) (84:50) [23:27:57:158]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (84:50) [23:27:57:189]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (c) (84:50) [23:27:57:220]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Cisco\vpnclient_setup.msi' against software restriction policy
MSI (c) (84:50) [23:27:57:236]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (84:50) [23:27:57:267]: SOFTWARE RESTRICTION POLICY: C:\Cisco\vpnclient_setup.msi is not digitally signed
MSI (c) (84:50) [23:27:57:298]: SOFTWARE RESTRICTION POLICY: C:\Cisco\vpnclient_setup.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (84:50) [23:27:57:330]: Cloaking enabled.
MSI (c) (84:50) [23:27:57:345]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (84:50) [23:27:57:376]: End dialog not enabled
MSI (c) (84:50) [23:27:57:392]: Original package ==> C:\Cisco\vpnclient_setup.msi
MSI (c) (84:50) [23:27:57:423]: Package we're running from ==> C:\Cisco\vpnclient_setup.msi
MSI (c) (84:50) [23:27:57:454]: APPCOMPAT: Compatibility mode property overrides found.
MSI (c) (84:50) [23:27:57:470]: APPCOMPAT: looking for appcompat database entry with ProductCode '{467D5E81-8349-4892-9E81-C3674ED8E451}'.
MSI (c) (84:50) [23:27:57:501]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (84:50) [23:27:57:532]: MSCOREE not loaded loading copy from system32
MSI (c) (84:50) [23:27:57:564]: Machine policy value 'TransformsSecure' is 0
MSI (c) (84:50) [23:27:57:610]: User policy value 'TransformsAtSource' is 0
MSI (c) (84:50) [23:27:57:626]: Machine policy value 'DisablePatch' is 0
MSI (c) (84:50) [23:27:57:657]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (84:50) [23:27:57:673]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (84:50) [23:27:57:688]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (84:50) [23:27:57:720]: Enabling baseline caching for this transaction since all active patches are MSI 3.0 style MSPs or at least one MSI 3.0 minor update patch is active
MSI (c) (84:50) [23:27:57:751]: APPCOMPAT: looking for appcompat database entry with ProductCode '{467D5E81-8349-4892-9E81-C3674ED8E451}'.
MSI (c) (84:50) [23:27:57:766]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (84:50) [23:27:57:798]: Transforms are not secure.
MSI (c) (84:50) [23:27:57:813]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Cisco\log.txt'.
MSI (c) (84:50) [23:27:57:844]: Command Line: CURRENTDIRECTORY=C:\Cisco CLIENTUILEVEL=0 CLIENTPROCESSID=1668
MSI (c) (84:50) [23:27:57:860]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{A8E53AA2-297F-4262-9996-753440EF4AB0}'.
MSI (c) (84:50) [23:27:57:891]: Product Code passed to Engine.Initialize: ''
MSI (c) (84:50) [23:27:57:922]: Product Code from property table before transforms: '{467D5E81-8349-4892-9E81-C3674ED8E451}'
MSI (c) (84:50) [23:27:57:938]: Product Code from property table after transforms: '{467D5E81-8349-4892-9E81-C3674ED8E451}'
MSI (c) (84:50) [23:27:57:969]: Product not registered: beginning first-time install
MSI (c) (84:50) [23:27:57:985]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (84:50) [23:27:58:000]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (84:50) [23:27:58:032]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (84:50) [23:27:58:063]: Adding new sources is allowed.
MSI (c) (84:50) [23:27:58:078]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (84:50) [23:27:58:110]: Package name extracted from package path: 'vpnclient_setup.msi'
MSI (c) (84:50) [23:27:58:125]: Package to be registered: 'vpnclient_setup.msi'
MSI (c) (84:50) [23:27:58:156]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (84:50) [23:27:58:172]: Machine policy value 'DisableMsi' is 0
MSI (c) (84:50) [23:27:58:203]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (84:50) [23:27:58:234]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (84:50) [23:27:58:250]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (84:50) [23:27:58:281]: Running product '{467D5E81-8349-4892-9E81-C3674ED8E451}' with elevated privileges: Product is assigned.
MSI (c) (84:50) [23:27:58:297]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Cisco'.
MSI (c) (84:50) [23:27:58:312]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (84:50) [23:27:58:359]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '1668'.
MSI (c) (84:50) [23:27:58:375]: PROPERTY CHANGE: Adding MsiSystemRebootPending property. Its value is '1'.
MSI (c) (84:50) [23:27:58:390]: TRANSFORMS property is now:
MSI (c) (84:50) [23:27:58:422]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (84:50) [23:27:58:437]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming
MSI (c) (84:50) [23:27:58:468]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\Favorites
MSI (c) (84:50) [23:27:58:500]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (c) (84:50) [23:27:58:515]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\Documents
MSI (c) (84:50) [23:27:58:546]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (c) (84:50) [23:27:58:562]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Recent
MSI (c) (84:50) [23:27:58:578]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\SendTo
MSI (c) (84:50) [23:27:58:609]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Templates
MSI (c) (84:50) [23:27:58:624]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (c) (84:50) [23:27:58:671]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Local
MSI (c) (84:50) [23:27:58:687]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\Pictures
MSI (c) (84:50) [23:27:58:702]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (84:50) [23:27:58:734]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (84:50) [23:27:58:749]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (c) (84:50) [23:27:58:780]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu
MSI (c) (84:50) [23:27:58:827]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (c) (84:50) [23:27:58:858]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (c) (84:50) [23:27:58:874]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (c) (84:50) [23:27:58:890]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI (c) (84:50) [23:27:58:921]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Start Menu
MSI (c) (84:50) [23:27:58:936]: SHELL32::SHGetFolderPath returned: C:\Users\Pepsi\Desktop
MSI (c) (84:50) [23:27:58:968]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (c) (84:50) [23:27:59:014]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (c) (84:50) [23:27:59:030]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (c) (84:50) [23:27:59:061]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (c) (84:50) [23:27:59:077]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (c) (84:50) [23:27:59:092]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (84:50) [23:27:59:124]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (84:50) [23:27:59:139]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Pepsi'.
MSI (c) (84:50) [23:27:59:170]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (84:50) [23:27:59:186]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Cisco\vpnclient_setup.msi'.
MSI (c) (84:50) [23:27:59:217]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Cisco\vpnclient_setup.msi'.
MSI (c) (84:50) [23:27:59:233]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (c) (84:50) [23:27:59:280]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Cisco\'.
MSI (c) (84:50) [23:27:59:311]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Cisco\'.
MSI (c) (84:9C) [23:27:59:342]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '5.00'.
=== Logging started: 5/25/2010 23:27:59 ===
MSI (c) (84:50) [23:27:59:389]: Note: 1: 2205 2: 3: PatchPackage
MSI (c) (84:50) [23:27:59:404]: Machine policy value 'DisableRollback' is 0
MSI (c) (84:50) [23:27:59:436]: User policy value 'DisableRollback' is 0
MSI (c) (84:50) [23:27:59:451]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (84:50) [23:27:59:467]: Note: 1: 2262 2: Font 3: -2147287038
MSI (c) (84:50) [23:27:59:498]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (84:50) [23:27:59:514]: Doing action: INSTALL
Action 23:27:59: INSTALL.
Action start 23:27:59: INSTALL.
MSI (c) (84:50) [23:27:59:592]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (84:50) [23:27:59:607]: Running UISequence
MSI (c) (84:50) [23:27:59:638]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (84:50) [23:27:59:654]: Doing action: WiseStartup
Action 23:27:59: WiseStartup.
Action start 23:27:59: WiseStartup.
MSI (c) (84:50) [23:27:59:748]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WiseStartup'
MSI (c) (84:50) [23:27:59:779]: Creating MSIHANDLE (1) of type 790542 for thread 1872
MSI (c) (84:F8) [23:27:59:826]: Invoking remote custom action. DLL: C:\Users\Pepsi\AppData\Local\Temp\MSI5545.tmp, Entrypoint: Startup
MSI (c) (84:3C) [23:27:59:841]: Cloaking enabled.
MSI (c) (84:3C) [23:27:59:872]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (84:3C) [23:27:59:888]: Connected to service for CA interface.
MSI (c) (84!40) [23:27:59:997]: Creating MSIHANDLE (2) of type 790541 for thread 3904
MSI (c) (84!40) [23:28:00:060]: Creating MSIHANDLE (3) of type 790540 for thread 3904
MSI (c) (84!40) [23:28:00:075]: Creating MSIHANDLE (4) of type 790531 for thread 3904
Action 23:28:00: Startup. Extracting temporary binaries...
MSI (c) (84!40) [23:28:00:122]: Creating MSIHANDLE (5) of type 790531 for thread 3904
Startup: Icon
MSI (c) (84!40) [23:28:00:184]: Closing MSIHANDLE (5) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:200]: Creating MSIHANDLE (6) of type 790531 for thread 3904
Startup: Calldnmsica1.0525718E_E263_4E57_A46E_C584C25A7F93
MSI (c) (84!40) [23:28:00:247]: Closing MSIHANDLE (6) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:278]: Creating MSIHANDLE (7) of type 790531 for thread 3904
Startup: WiseDlgSequence
MSI (c) (84!40) [23:28:00:325]: Closing MSIHANDLE (7) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:340]: Creating MSIHANDLE (8) of type 790531 for thread 3904
Startup: Complete
MSI (c) (84!40) [23:28:00:387]: Closing MSIHANDLE (8) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:418]: Creating MSIHANDLE (9) of type 790531 for thread 3904
Startup: New
MSI (c) (84!40) [23:28:00:465]: Closing MSIHANDLE (9) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:481]: Creating MSIHANDLE (10) of type 790531 for thread 3904
Startup: Up
MSI (c) (84!40) [23:28:00:528]: Closing MSIHANDLE (10) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:559]: Creating MSIHANDLE (11) of type 790531 for thread 3904
Startup: side16
MSI (c) (84!40) [23:28:00:590]: Closing MSIHANDLE (11) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:637]: Creating MSIHANDLE (12) of type 790531 for thread 3904
Startup: Custom
MSI (c) (84!40) [23:28:00:668]: Closing MSIHANDLE (12) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:699]: Creating MSIHANDLE (13) of type 790531 for thread 3904
Startup: top16
MSI (c) (84!40) [23:28:00:730]: Closing MSIHANDLE (13) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:777]: Creating MSIHANDLE (14) of type 790531 for thread 3904
Startup: trash1
MSI (c) (84!40) [23:28:00:871]: Closing MSIHANDLE (14) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:886]: Creating MSIHANDLE (15) of type 790531 for thread 3904
Startup: Music
MSI (c) (84!40) [23:28:00:933]: Closing MSIHANDLE (15) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:00:964]: Creating MSIHANDLE (16) of type 790531 for thread 3904
Startup: Typical
MSI (c) (84!40) [23:28:01:011]: Closing MSIHANDLE (16) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:027]: Creating MSIHANDLE (17) of type 790531 for thread 3904
Startup: CD
MSI (c) (84!40) [23:28:01:074]: Closing MSIHANDLE (17) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:105]: Creating MSIHANDLE (18) of type 790531 for thread 3904
Startup: Callwisepatch
MSI (c) (84!40) [23:28:01:152]: Closing MSIHANDLE (18) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:167]: Creating MSIHANDLE (19) of type 790531 for thread 3904
Startup: Info
MSI (c) (84!40) [23:28:01:214]: Closing MSIHANDLE (19) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:261]: Creating MSIHANDLE (20) of type 790531 for thread 3904
Startup: WiseCustomCall
MSI (c) (84!40) [23:28:01:323]: Closing MSIHANDLE (20) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:354]: Creating MSIHANDLE (21) of type 790531 for thread 3904
Startup: WiseCustCall64
MSI (c) (84!40) [23:28:01:417]: Closing MSIHANDLE (21) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:448]: Creating MSIHANDLE (22) of type 790531 for thread 3904
Startup: Callmsihelper
MSI (c) (84!40) [23:28:01:495]: Closing MSIHANDLE (22) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:510]: Creating MSIHANDLE (23) of type 790531 for thread 3904
Startup: WiseCustomCalla
MSI (c) (84!40) [23:28:01:588]: Closing MSIHANDLE (23) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:620]: Creating MSIHANDLE (24) of type 790531 for thread 3904
Startup: Callcscavbs_copyinifiles
MSI (c) (84!40) [23:28:01:666]: Closing MSIHANDLE (24) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:682]: Creating MSIHANDLE (25) of type 790531 for thread 3904
Startup: Callwiseapi
MSI (c) (84!40) [23:28:01:729]: Closing MSIHANDLE (25) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:760]: Creating MSIHANDLE (26) of type 790531 for thread 3904
Startup: WiseCustomCalla1
MSI (c) (84!40) [23:28:01:838]: Closing MSIHANDLE (26) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:869]: Creating MSIHANDLE (27) of type 790531 for thread 3904
Startup: Callmsihelper2
MSI (c) (84!40) [23:28:01:947]: Closing MSIHANDLE (27) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:01:963]: Creating MSIHANDLE (28) of type 790531 for thread 3904
Startup: Callmsihelper9
MSI (c) (84!40) [23:28:02:025]: Closing MSIHANDLE (28) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:041]: Creating MSIHANDLE (29) of type 790531 for thread 3904
Startup: Callmsihelper10
MSI (c) (84!40) [23:28:02:088]: Closing MSIHANDLE (29) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:103]: Creating MSIHANDLE (30) of type 790531 for thread 3904
Startup: Callmsihelper12
MSI (c) (84!40) [23:28:02:166]: Closing MSIHANDLE (30) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:181]: Creating MSIHANDLE (31) of type 790531 for thread 3904
Startup: Callmsihelper13
MSI (c) (84!40) [23:28:02:228]: Closing MSIHANDLE (31) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:259]: Creating MSIHANDLE (32) of type 790531 for thread 3904
Startup: InstHelperDll
MSI (c) (84!40) [23:28:02:306]: Closing MSIHANDLE (32) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:368]: Creating MSIHANDLE (33) of type 790531 for thread 3904
Startup: Callmsihelper14
MSI (c) (84!40) [23:28:02:446]: Closing MSIHANDLE (33) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:509]: Creating MSIHANDLE (34) of type 790531 for thread 3904
Startup: Calldneca6.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D
MSI (c) (84!40) [23:28:02:696]: Closing MSIHANDLE (34) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:727]: Creating MSIHANDLE (35) of type 790531 for thread 3904
Startup: Calldneca.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D
MSI (c) (84!40) [23:28:02:774]: Closing MSIHANDLE (35) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:02:930]: Creating MSIHANDLE (36) of type 790531 for thread 3904
Startup: Calldneca3.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D
MSI (c) (84!40) [23:28:02:977]: Closing MSIHANDLE (36) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:03:008]: Creating MSIHANDLE (37) of type 790531 for thread 3904
Startup: Calldneca7.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D
MSI (c) (84!40) [23:28:03:055]: Closing MSIHANDLE (37) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:03:070]: Creating MSIHANDLE (38) of type 790531 for thread 3904
Startup: Calldneca4.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D
MSI (c) (84!40) [23:28:03:117]: Closing MSIHANDLE (38) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:03:148]: Closing MSIHANDLE (3) of type 790540 for thread 3904
MSI (c) (84!40) [23:28:03:180]: Closing MSIHANDLE (4) of type 790531 for thread 3904
MSI (c) (84!40) [23:28:03:195]: Closing MSIHANDLE (2) of type 790541 for thread 3904
MSI (c) (84:F8) [23:28:03:226]: Closing MSIHANDLE (1) of type 790542 for thread 1872
Action ended 23:28:03: WiseStartup. Return value 1.
MSI (c) (84:50) [23:28:03:273]: Doing action: LaunchConditions
Action 23:28:03: LaunchConditions. Evaluating launch conditions...
Action start 23:28:03: LaunchConditions.
Action ended 23:28:03: LaunchConditions. Return value 1.
MSI (c) (84:50) [23:28:03:367]: Doing action: SetDLLDIR
Action 23:28:03: SetDLLDIR.
Action start 23:28:03: SetDLLDIR.
MSI (c) (84:50) [23:28:03:445]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetDLLDIR'
MSI (c) (84:50) [23:28:03:460]: PROPERTY CHANGE: Adding DLLDIR property. Its value is '{467D5E81-8349-4892-9E81-C3674ED8E451}'.
Action ended 23:28:03: SetDLLDIR. Return value 1.
MSI (c) (84:50) [23:28:03:507]: Doing action: SetDLLLOC
Action 23:28:03: SetDLLLOC.
Action start 23:28:03: SetDLLLOC.
MSI (c) (84:50) [23:28:03:585]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetDLLLOC'
MSI (c) (84:50) [23:28:03:616]: PROPERTY CHANGE: Adding DLLLOC property. Its value is 'C:\Users\Pepsi\AppData\Local\Temp\{467D5E81-8349-4892-9E81-C3674ED8E451}\'.
Action ended 23:28:03: SetDLLLOC. Return value 1.
MSI (c) (84:50) [23:28:03:648]: Doing action: CsCa_CopyInstHelperDll
Action 23:28:03: CsCa_CopyInstHelperDll.
Action start 23:28:03: CsCa_CopyInstHelperDll.
MSI (c) (84:50) [23:28:03:726]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'CsCa_CopyInstHelperDll'
MSI (c) (84:50) [23:28:03:772]: Creating MSIHANDLE (39) of type 790542 for thread 1872
MSI (c) (84:40) [23:28:03:804]: Invoking remote custom action. DLL: C:\Users\Pepsi\AppData\Local\Temp\MSI64DF.tmp, Entrypoint: f0
MSI (c) (84!6C) [23:28:03:819]: Creating MSIHANDLE (40) of type 790541 for thread 1644
MSI (c) (84!6C) [23:28:03:866]: Creating MSIHANDLE (41) of type 790540 for thread 1644
MSI (c) (84!6C) [23:28:03:897]: Creating MSIHANDLE (42) of type 790531 for thread 1644
MSI (c) (84!6C) [23:28:03:928]: Closing MSIHANDLE (41) of type 790540 for thread 1644
MSI (c) (84!6C) [23:28:03:960]: Closing MSIHANDLE (42) of type 790531 for thread 1644
MSI (c) (84!6C) [23:28:03:991]: Closing MSIHANDLE (40) of type 790541 for thread 1644
MSI (c) (84!6C) [23:28:04:022]: PROPERTY CHANGE: Adding CsProp_CopyInstHelperDll property. Its value is '1'.
MSI (c) (84:40) [23:28:04:053]: Closing MSIHANDLE (39) of type 790542 for thread 1872
Action ended 23:28:04: CsCa_CopyInstHelperDll. Return value 1.
MSI (c) (84:50) [23:28:04:100]: Skipping action: ClearDisableUAP (condition is false)
MSI (c) (84:50) [23:28:04:116]: Skipping action: CsCaErr_NTNotSupported1 (condition is false)
MSI (c) (84:50) [23:28:04:147]: Skipping action: CsCaErr_Win64BitNotSupported2 (condition is false)
MSI (c) (84:50) [23:28:04:162]: Skipping action: SetPatchMode (condition is false)
MSI (c) (84:50) [23:28:04:194]: Skipping action: SetPatchReinstallMode (condition is false)
MSI (c) (84:50) [23:28:04:209]: Doing action: CsCaDll_AreWeInstalled1
Action 23:28:04: CsCaDll_AreWeInstalled1. Searching for Installed VPN Client...
Action start 23:28:04: CsCaDll_AreWeInstalled1.
MSI (c) (84:50) [23:28:04:287]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'CsCaDll_AreWeInstalled1'
MSI (c) (84:50) [23:28:04:334]: Creating MSIHANDLE (43) of type 790542 for thread 1872
MSI (c) (84:CC) [23:28:04:365]: Invoking remote custom action. DLL: C:\Users\Pepsi\AppData\Local\Temp\MSI6702.tmp, Entrypoint: f2
MSI (c) (84!18) [23:28:04:396]: PROPERTY CHANGE: Adding CLIENT_INSTALLED property. Its value is '0'.
MSI (c) (84:CC) [23:28:04:459]: Closing MSIHANDLE (43) of type 790542 for thread 1872
Action ended 23:28:04: CsCaDll_AreWeInstalled1. Return value 1.
MSI (c) (84:50) [23:28:04:506]: Skipping action: CsCaDll_AreWeInstalled (condition is false)
MSI (c) (84:50) [23:28:04:537]: Skipping action: CsCaProp_SetLegacyClient2Unity (condition is false)
MSI (c) (84:50) [23:28:04:552]: Skipping action: CsCaDll_ClientAlreadyInstalledOnVista (condition is false)
MSI (c) (84:50) [23:28:04:584]: Doing action: Setup_Dialog
Action 23:28:04: Setup_Dialog.
Action start 23:28:04: Setup_Dialog.
MSI (c) (84:50) [23:28:04:662]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Setup_Dialog'
Info 2898. For MSSansSerif8 textstyle, the system created a 'MS Sans Serif' font, in 1 character set, of 13 pixels height.
Info 2898. For Arial10 textstyle, the system created a 'Arial' font, in 1 character set, of 16 pixels height.
Info 2898. For Arial14 textstyle, the system created a 'Arial' font, in 1 character set, of 22 pixels height.
Action 23:28:04: Setup_Dialog. Dialog created
Action ended 23:28:04: Setup_Dialog. Return value 1.
MSI (c) (84:50) [23:28:04:818]: Doing action: FindRelatedProducts
Action 23:28:04: FindRelatedProducts. Searching for related applications
Action start 23:28:04: FindRelatedProducts.
MSI (c) (84:50) [23:28:04:880]: Note: 1: 2262 2: Upgrade 3: -2147287038
Action ended 23:28:04: FindRelatedProducts. Return value 1.
MSI (c) (84:50) [23:28:04:927]: Doing action: AppSearch
Action 23:28:04: AppSearch. Searching for installed applications...
Action start 23:28:04: AppSearch.
AppSearch: Property: DN_DNE_PI_ORDER_REG_VER.0525718E_E263_4E57_A46E_C584C25A7F93
Signature: AppRegOrder.0525718E_E263_4E57_A46E_C584C25A7F93
MSI (c) (84:50) [23:28:05:020]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (c) (84:50) [23:28:05:052]: Note: 1: 2262 2: CompLocator 3: -2147287038
MSI (c) (84:50) [23:28:05:067]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\DNE\Parameters\Order 3: 2
MSI (c) (84:50) [23:28:05:098]: Note: 1: 2262 2: IniLocator 3: -2147287038
MSI (c) (84:50) [23:28:05:114]: Note: 1: 2262 2: DrLocator 3: -2147287038
Action ended 23:28:05: AppSearch. Return value 1.
MSI (c) (84:50) [23:28:05:161]: Skipping action: CCPSearch (condition is false)
MSI (c) (84:50) [23:28:05:192]: Skipping action: CCPDialog (condition is false)
MSI (c) (84:50) [23:28:05:208]: Skipping action: RMCCPSearch (condition is false)
MSI (c) (84:50) [23:28:05:239]: Doing action: ValidateProductID
Action 23:28:05: ValidateProductID.
Action start 23:28:05: ValidateProductID.
Action ended 23:28:05: ValidateProductID. Return value 1.
MSI (c) (84:50) [23:28:05:317]: Doing action: CostInitialize
Action 23:28:05: CostInitialize. Computing space requirements...
Action start 23:28:05: CostInitialize.
MSI (c) (84:50) [23:28:05:410]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (c) (84:50) [23:28:05:426]: Baseline: Sorting baselines for {467D5E81-8349-4892-9E81-C3674ED8E451}.
MSI (c) (84:50) [23:28:05:442]: Baseline: New baseline 5.0.7 from transaction.
MSI (c) (84:50) [23:28:05:473]: Baseline: Sorted order Native: Order 0.
MSI (c) (84:50) [23:28:05:488]: Baseline Data Table:
MSI (c) (84:50) [23:28:05:520]: ProductCode: {467D5E81-8349-4892-9E81-C3674ED8E451} Version: 5.0.7 Attributes: 0 PatchId: Native BaselineId: -2147483648 Order: 0
MSI (c) (84:50) [23:28:05:551]: Baseline File Table:
MSI (c) (84:50) [23:28:05:566]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'F:\'.
MSI (c) (84:50) [23:28:05:598]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
Action ended 23:28:05: CostInitialize. Return value 1.
MSI (c) (84:50) [23:28:05:644]: Doing action: FileCost
Action 23:28:05: FileCost. Computing space requirements...
Action start 23:28:05: FileCost.
MSI (c) (84:50) [23:28:05:722]: Note: 1: 2262 2: MsiAssembly 3: -2147287038
MSI (c) (84:50) [23:28:05:738]: Note: 1: 2262 2: RemoveFile 3: -2147287038
MSI (c) (84:50) [23:28:05:769]: Note: 1: 2262 2: MoveFile 3: -2147287038
MSI (c) (84:50) [23:28:05:785]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (c) (84:50) [23:28:05:816]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:50) [23:28:05:832]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:50) [23:28:05:863]: Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (c) (84:50) [23:28:05:894]: Note: 1: 2262 2: IniFile 3: -2147287038
MSI (c) (84:50) [23:28:05:910]: Note: 1: 2262 2: ReserveCost 3: -2147287038
Action ended 23:28:05: FileCost. Return value 1.
MSI (c) (84:50) [23:28:05:956]: Doing action: IsolateComponents
Action 23:28:05: IsolateComponents.
Action start 23:28:06: IsolateComponents.
MSI (c) (84:50) [23:28:06:019]: Note: 1: 2262 2: BindImage 3: -2147287038
MSI (c) (84:50) [23:28:06:050]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038
MSI (c) (84:50) [23:28:06:066]: Note: 1: 2205 2: 3: Patch
Action ended 23:28:06: IsolateComponents. Return value 1.
MSI (c) (84:50) [23:28:06:112]: Doing action: CostFinalize
Action 23:28:06: CostFinalize. Computing space requirements...
Action start 23:28:06: CostFinalize.
MSI (c) (84:50) [23:28:06:175]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (c) (84:50) [23:28:06:206]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (c) (84:50) [23:28:06:222]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (c) (84:50) [23:28:06:253]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (c) (84:50) [23:28:06:268]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (c) (84:50) [23:28:06:300]: Note: 1: 2205 2: 3: Patch
MSI (c) (84:50) [23:28:06:315]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'F:\'.
MSI (c) (84:50) [23:28:06:331]: PROPERTY CHANGE: Adding WWWROOT property. Its value is 'F:\'.
MSI (c) (84:50) [23:28:06:362]: PROPERTY CHANGE: Adding GAC property. Its value is 'F:\'.
MSI (c) (84:50) [23:28:06:378]: PROPERTY CHANGE: Adding System16Folder property. Its value is 'C:\Windows\'.
MSI (c) (84:50) [23:28:06:409]: PROPERTY CHANGE: Adding Drivers property. Its value is 'C:\Windows\system32\Drivers\'.
MSI (c) (84:50) [23:28:06:424]: PROPERTY CHANGE: Adding WinSxS property. Its value is 'C:\Windows\'.
MSI (c) (84:50) [23:28:06:440]: PROPERTY CHANGE: Adding ProfilesFolder property. Its value is 'C:\Windows\'.
MSI (c) (84:50) [23:28:06:471]: PROPERTY CHANGE: Adding Cisco_Systems_VPN_Client property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cisco Systems VPN Client\'.
MSI (c) (84:50) [23:28:06:487]: PROPERTY CHANGE: Adding Cisco_Systems property. Its value is 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cisco Systems\'.
MSI (c) (84:50) [23:28:06:518]: PROPERTY CHANGE: Adding CommonFiles64Folder.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D property. Its value is 'C:\Program Files\Common Files\'.
MSI (c) (84:50) [23:28:06:534]: PROPERTY CHANGE: Adding D64_CFDetNet.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D property. Its value is 'C:\Program Files\Common Files\Deterministic Networks\'.
MSI (c) (84:50) [23:28:06:565]: PROPERTY CHANGE: Adding D64_DNCF.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D property. Its value is 'C:\Program Files\Common Files\Deterministic Networks\Common Files\'.
MSI (c) (84:50) [23:28:06:580]: PROPERTY CHANGE: Adding D64_DNE.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D property. Its value is 'C:\Program Files\Common Files\Deterministic Networks\DNE\'.
MSI (c) (84:50) [23:28:06:596]: PROPERTY CHANGE: Adding CommonFiles64Folder.0525718E_E263_4E57_A46E_C584C25A7F93 property. Its value is 'C:\Program Files\Common Files\'.
MSI (c) (84:50) [23:28:06:627]: PROPERTY CHANGE: Adding INSTALLDIR2 property. Its value is 'C:\Program Files (x86)\VPN Client\'.
MSI (c) (84:50) [23:28:06:643]: PROPERTY CHANGE: Adding INSTALLDIR1 property. Its value is 'C:\Program Files (x86)\Cisco Systems\'.
MSI (c) (84:50) [23:28:06:674]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\'.
MSI (c) (84:50) [23:28:06:690]: PROPERTY CHANGE: Adding updates property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\updates\'.
MSI (c) (84:50) [23:28:06:721]: PROPERTY CHANGE: Adding TempInstall property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\TempInstall\'.
MSI (c) (84:50) [23:28:06:736]: PROPERTY CHANGE: Adding Resources property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\Resources\'.
MSI (c) (84:50) [23:28:06:752]: PROPERTY CHANGE: Adding Profiles property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\Profiles\'.
MSI (c) (84:50) [23:28:06:783]: PROPERTY CHANGE: Adding Logs property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\Logs\'.
MSI (c) (84:50) [23:28:06:799]: PROPERTY CHANGE: Adding include property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\include\'.
MSI (c) (84:50) [23:28:06:830]: PROPERTY CHANGE: Adding Certificates property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\Certificates\'.
MSI (c) (84:50) [23:28:06:846]: PROPERTY CHANGE: Adding accessible property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\accessible\'.
MSI (c) (84:50) [23:28:06:861]: PROPERTY CHANGE: Adding Setup property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\Setup\'.
MSI (c) (84:50) [23:28:06:892]: PROPERTY CHANGE: Adding Languages property. Its value is 'C:\Program Files (x86)\Cisco Systems\VPN Client\Languages\'.
MSI (c) (84:50) [23:28:06:908]: Target path resolution complete. Dumping Directory table...
MSI (c) (84:50) [23:28:06:939]: Note: target paths subject to change (via custom actions or browsing)
MSI (c) (84:50) [23:28:06:970]: Dir (target): Key: TARGETDIR , Object: F:\
MSI (c) (84:50) [23:28:07:002]: Dir (target): Key: WWWROOT , Object: F:\
MSI (c) (84:50) [23:28:07:033]: Dir (target): Key: GAC , Object: F:\
MSI (c) (84:50) [23:28:07:064]: Dir (target): Key: MyPicturesFolder , Object: C:\Users\Pepsi\Pictures\
MSI (c) (84:50) [23:28:07:080]: Dir (target): Key: CommonAppDataFolder , Object: C:\ProgramData\
MSI (c) (84:50) [23:28:07:111]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (c) (84:50) [23:28:07:142]: Dir (target): Key: System16Folder , Object: C:\Windows\
MSI (c) (84:50) [23:28:07:173]: Dir (target): Key: TemplateFolder , Object: C:\ProgramData\Microsoft\Windows\Templates\
MSI (c) (84:50) [23:28:07:189]: Dir (target): Key: AdminToolsFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
MSI (c) (84:50) [23:28:07:220]: Dir (target): Key: System64Folder , Object: C:\Windows\system32\
MSI (c) (84:50) [23:28:07:251]: Dir (target): Key: Drivers , Object: C:\Windows\system32\Drivers\
MSI (c) (84:50) [23:28:07:282]: Dir (target): Key: WinSxS , Object: C:\Windows\
MSI (c) (84:50) [23:28:07:298]: Dir (target): Key: SystemFolder , Object: C:\Windows\SysWOW64\
MSI (c) (84:50) [23:28:07:345]: Dir (target): Key: FontsFolder , Object: C:\Windows\Fonts\
MSI (c) (84:50) [23:28:07:360]: Dir (target): Key: TempFolder , Object: C:\Users\Pepsi\AppData\Local\Temp\
MSI (c) (84:50) [23:28:07:392]: Dir (target): Key: ProfilesFolder , Object: C:\Windows\
MSI (c) (84:50) [23:28:07:423]: Dir (target): Key: AppDataFolder , Object: C:\Users\Pepsi\AppData\Roaming\
MSI (c) (84:50) [23:28:07:454]: Dir (target): Key: FavoritesFolder , Object: C:\Users\Pepsi\Favorites\
MSI (c) (84:50) [23:28:07:470]: Dir (target): Key: NetHoodFolder , Object: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
MSI (c) (84:50) [23:28:07:501]: Dir (target): Key: DesktopFolder , Object: C:\Users\Public\Desktop\
MSI (c) (84:50) [23:28:07:532]: Dir (target): Key: RecentFolder , Object: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Recent\
MSI (c) (84:50) [23:28:07:563]: Dir (target): Key: StartMenuFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\
MSI (c) (84:50) [23:28:07:579]: Dir (target): Key: ProgramMenuFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
MSI (c) (84:50) [23:28:07:610]: Dir (target): Key: Cisco_Systems_VPN_Client , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cisco Systems VPN Client\
MSI (c) (84:50) [23:28:07:641]: Dir (target): Key: StartupFolder , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
MSI (c) (84:50) [23:28:07:672]: Dir (target): Key: Cisco_Systems , Object: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cisco Systems\
MSI (c) (84:50) [23:28:07:719]: Dir (target): Key: PersonalFolder , Object: C:\Users\Pepsi\Documents\
MSI (c) (84:50) [23:28:07:797]: Dir (target): Key: SendToFolder , Object: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\SendTo\
MSI (c) (84:50) [23:28:07:828]: Dir (target): Key: PrintHoodFolder , Object: C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
MSI (c) (84:50) [23:28:07:875]: Dir (target): Key: LocalAppDataFolder , Object: C:\Users\Pepsi\AppData\Local\
MSI (c) (84:50) [23:28:07:938]: Dir (target): Key: ProgramFiles64Folder , Object: C:\Program Files\
MSI (c) (84:50) [23:28:08:000]: Dir (target): Key: CommonFiles64Folder , Object: C:\Program Files\Common Files\
MSI (c) (84:50) [23:28:08:078]: Dir (target): Key: CommonFiles64Folder.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D , Object: C:\Program Files\Common Files\
MSI (c) (84:50) [23:28:08:109]: Dir (target): Key: D64_CFDetNet.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D , Object: C:\Program Files\Common Files\Deterministic Networks\
MSI (c) (84:50) [23:28:08:140]: Dir (target): Key: D64_DNCF.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D , Object: C:\Program Files\Common Files\Deterministic Networks\Common Files\
MSI (c) (84:50) [23:28:08:187]: Dir (target): Key: D64_DNE.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D , Object: C:\Program Files\Common Files\Deterministic Networks\DNE\
MSI (c) (84:50) [23:28:08:203]: Dir (target): Key: CommonFiles64Folder.0525718E_E263_4E57_A46E_C584C25A7F93 , Object: C:\Program Files\Common Files\
MSI (c) (84:50) [23:28:08:234]: Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files (x86)\
MSI (c) (84:50) [23:28:08:265]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
MSI (c) (84:50) [23:28:08:296]: Dir (target): Key: INSTALLDIR2 , Object: C:\Program Files (x86)\VPN Client\
MSI (c) (84:50) [23:28:08:312]: Dir (target): Key: INSTALLDIR1 , Object: C:\Program Files (x86)\Cisco Systems\
MSI (c) (84:50) [23:28:08:343]: Dir (target): Key: INSTALLDIR , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\
MSI (c) (84:50) [23:28:08:374]: Dir (target): Key: updates , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\updates\
MSI (c) (84:50) [23:28:08:406]: Dir (target): Key: TempInstall , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\TempInstall\
MSI (c) (84:50) [23:28:08:421]: Dir (target): Key: Resources , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\Resources\
MSI (c) (84:50) [23:28:08:452]: Dir (target): Key: Profiles , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\Profiles\
MSI (c) (84:50) [23:28:08:484]: Dir (target): Key: Logs , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\Logs\
MSI (c) (84:50) [23:28:08:515]: Dir (target): Key: include , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\include\
MSI (c) (84:50) [23:28:08:546]: Dir (target): Key: Certificates , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\Certificates\
MSI (c) (84:50) [23:28:08:562]: Dir (target): Key: accessible , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\accessible\
MSI (c) (84:50) [23:28:08:593]: Dir (target): Key: Setup , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\Setup\
MSI (c) (84:50) [23:28:08:624]: Dir (target): Key: Languages , Object: C:\Program Files (x86)\Cisco Systems\VPN Client\Languages\
MSI (c) (84:50) [23:28:08:655]: Note: 1: 2262 2: RemoveFile 3: -2147287038
Action ended 23:28:08: CostFinalize. Return value 1.
MSI (c) (84:50) [23:28:08:733]: Doing action: MigrateFeatureStates
Action 23:28:08: MigrateFeatureStates. Migrating feature states from related applications
Action start 23:28:08: MigrateFeatureStates.
Action ended 23:28:08: MigrateFeatureStates. Return value 0.
MSI (c) (84:50) [23:28:08:889]: Doing action: SetWizardProperty1
Action 23:28:08: SetWizardProperty1.
Action start 23:28:08: SetWizardProperty1.
MSI (c) (84:50) [23:28:08:967]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'SetWizardProperty1'
MSI (c) (84:50) [23:28:08:998]: PROPERTY CHANGE: Adding WiseCurrentWizard property. Its value is 'Welcome_Dialog'.
Action ended 23:28:09: SetWizardProperty1. Return value 1.
MSI (c) (84:50) [23:28:09:061]: Doing action: Welcome_Dialog
Action 23:28:09: Welcome_Dialog.
Action start 23:28:09: Welcome_Dialog.
MSI (c) (84:50) [23:28:09:139]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Welcome_Dialog'
Action 23:28:09: Welcome_Dialog. Dialog created
MSI (c) (84:AC) [23:28:09:217]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (c) (84:AC) [23:28:09:232]: Note: 1: 2262 2: ReserveCost 3: -2147287038
MSI (c) (84:AC) [23:28:09:264]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (c) (84:AC) [23:28:09:310]: Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (c) (84:AC) [23:28:09:342]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:09:373]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:388]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:09:420]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:451]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:09:482]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:513]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:09:607]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:638]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:09:669]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:700]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:09:732]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:763]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:09:778]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:810]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (c) (84:AC) [23:28:09:841]: Note: 1: 2262 2: BindImage 3: -2147287038
MSI (c) (84:AC) [23:28:09:872]: Note: 1: 2262 2: ProgId 3: -2147287038
MSI (c) (84:AC) [23:28:09:903]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (c) (84:AC) [23:28:09:934]: Note: 1: 2262 2: SelfReg 3: -2147287038
MSI (c) (84:AC) [23:28:09:950]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (c) (84:AC) [23:28:09:981]: Note: 1: 2262 2: Font 3: -2147287038
MSI (c) (84:AC) [23:28:10:012]: Note: 1: 2262 2: Class 3: -2147287038
MSI (c) (84:AC) [23:28:10:044]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceAvailable property. Its current value is '0'. Its new value: '124015160'.
MSI (c) (84:AC) [23:28:10:059]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRequired property. Its current value is '0'. Its new value: '50274'.
MSI (c) (84:AC) [23:28:10:090]: PROPERTY CHANGE: Modifying PrimaryVolumeSpaceRemaining property. Its current value is '0'. Its new value: '123964886'.
MSI (c) (84:AC) [23:28:10:122]: PROPERTY CHANGE: Adding PrimaryVolumePath property. Its value is 'C:'.
MSI (c) (84:9C) [23:28:43:755]: Doing action: WiseNextDlg
Action 23:28:43: WiseNextDlg.
Action start 23:28:43: WiseNextDlg.
MSI (c) (84:9C) [23:28:43:880]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WiseNextDlg'
MSI (c) (84:9C) [23:28:43:911]: Creating MSIHANDLE (44) of type 790542 for thread 156
MSI (c) (84:30) [23:28:43:942]: Creating MSIHANDLE (45) of type 0 for thread 3888
MSI (c) (84:30) [23:28:43:974]: Closing MSIHANDLE (45) of type 0 for thread 3888
MSI (c) (84:30) [23:28:44:005]: Closing MSIHANDLE (44) of type 790542 for thread 156
Action ended 23:28:44: WiseNextDlg. Return value 3.
DEBUG: Error 2896: Executing action WiseNextDlg failed.
Internal Error 2896. WiseNextDlg
Action ended 23:28:44: Welcome_Dialog. Return value 3.
MSI (c) (84:50) [23:28:44:145]: Doing action: Fatal_Error
Action 23:28:44: Fatal_Error.
Action start 23:28:44: Fatal_Error.
MSI (c) (84:50) [23:28:44:223]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Fatal_Error'
Action 23:28:44: Fatal_Error. Dialog created
MSI (c) (84:9C) [23:29:28:549]: Doing action: WiseCleanup
Action 23:29:28: WiseCleanup.
Action start 23:29:28: WiseCleanup.
MSI (c) (84:9C) [23:29:28:674]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WiseCleanup'
MSI (c) (84:9C) [23:29:28:721]: Creating MSIHANDLE (46) of type 790542 for thread 156
MSI (c) (84:60) [23:29:28:752]: Invoking remote custom action. DLL: C:\Users\Pepsi\AppData\Local\Temp\MSIB0B0.tmp, Entrypoint: Cleanup
MSI (c) (84:60) [23:29:28:783]: Closing MSIHANDLE (46) of type 790542 for thread 156
Action ended 23:29:28: WiseCleanup. Return value 1.
Action ended 23:29:28: Fatal_Error. Return value 2.
Action ended 23:29:28: INSTALL. Return value 3.
MSI (c) (84:50) [23:29:28:924]: Destroying RemoteAPI object.
MSI (c) (84:3C) [23:29:28:955]: Custom Action Manager thread ending.
Property(C): DiskPrompt = [ProductName] [1]
Property(C): UpgradeCode = {86FEE996-CAE7-4C44-B180-6E347EBE3052}
Property(C): Languages = C:\Program Files (x86)\Cisco Systems\VPN Client\Languages\
Property(C): InstallMode = Complete
Property(C): DN_Product_Version.dneorder64.0525718E_E263_4E57_A46E_C584C25A7F93 = 2.32.0.18030
Property(C): DN_PkgSrcRev.dneorder64.wsm.0525718E_E263_4E57_A46E_C584C25A7F93 = 1
Property(C): DN_DNE_PI_ORDER_DB_VER.0525718E_E263_4E57_A46E_C584C25A7F93 = 232
Property(C): DN_DNE_PI_ORDER_REG_VER.0525718E_E263_4E57_A46E_C584C25A7F93 = 0
Property(C): DN_BuildNumber.dneorder64.0525718E_E263_4E57_A46E_C584C25A7F93 = 18030
Property(C): CommonFiles64Folder.0525718E_E263_4E57_A46E_C584C25A7F93 = C:\Program Files\Common Files\
Property(C): ProductCode = {467D5E81-8349-4892-9E81-C3674ED8E451}
Property(C): ProductName = Cisco Systems VPN Client 5.0.07.0290
Property(C): ProductVersion = 5.0.7
Property(C): Manufacturer = Cisco Systems, Inc.
Property(C): CsProp_AllowSBLLaunches = 0
Property(C): ReinstallFileOlderVersion = o
Property(C): ReinstallRepair = r
Property(C): ErrorDialog = ErrorDialog
Property(C): Accept = No
Property(C): Setup = C:\Program Files (x86)\Cisco Systems\VPN Client\Setup\
Property(C): _WiseDialogSuffix = Setup
Property(C): CsProp_VAMTU = 1300
Property(C): ProductID = none
Property(C): CsProp_CvpnDrvDesc = "Cisco Systems Inc. IPSec Driver"
Property(C): CsProp_VPNGui = 0
Property(C): CsProp_CvpnDrvDependsOnService = DNE[~]
Property(C): CsProp_bIsNT = 0
Property(C): INSTALLDIR = C:\Program Files (x86)\Cisco Systems\VPN Client\
Property(C): PRIMARYFOLDER = INSTALLDIR
Property(C): ApplicationUsers = AllUsers
Property(C): INSTALLLEVEL = 3
Property(C): DefaultUIFont = Arial10
Property(C): WiseInitExistError = %s Version %s is already installed. You must uninstall the existing version before installing %s Version %s. Do you want to uninstall the existing version of %s?
Property(C): CsProp_VPNClient = 0
Property(C): CsProp_RasConnectionActive = 0
Property(C): WiseInitSpaceError = Could not create temporary file, not enough free temporary disk space. Please free up disk space and rerun this installation.
Property(C): WiseInitLangDefault = English,1033
Property(C): CsProp_LogViewer = 0
Property(C): CsProp_CiscoRebootFlag = 0
Property(C): WiseCRLF =
Property(C): WiseInitAdminError = You must have administrator rights to run this installation. Please login as an administrator and re-run this installation.
Property(C): SecureCustomProperties = INSTALLDIR
Property(C): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(C): WiseInitSuffix = Wizard...
Property(C): _WiseDialogFontDefault = {&MSSansSerif8}
Property(C): MaintenanceMode = Modify
Property(C): WiseInitPrefix = Initializing
Property(C): CsProp_WindowsOSVersion = 0
Property(C): MsiHiddenProperties = WISE_SQL_CONN_STR
Property(C): PALMUSERS = 0
Property(C): CsProp_LegacyClient = 0
Property(C): ShutdownOption = 1
Property(C): CsProp_DneInstPath = c:\bad_dir\
Property(C): CsProp_Ppptool = 0
Property(C): CsProp_SetMtu = 0
Property(C): _WiseDialogTitleFontDefault = {&Arial8}
Property(C): ProductLanguage = 1033
Property(C): _WiseDebugMode = 0
Property(C): WiseLangEncode = 1
Property(C): _WiseStatusMifInstall = VPNInstall.MIF
Property(C): _WiseStatusMifUninstall = VPNUnInstall.MIF
Property(C): _WiseStatusMifSerial = 123456
Property(C): _WiseStatusMifSMSVer = 2.0
Property(C): _WiseStatusMifPDFVer = 1.0
Property(C): SETMTUVALUE = 1300
Property(C): LAUNCHSETMTU = 1
Property(C): ReinstallFileVersion = o
Property(C): ARPNOMODIFY = 1
Property(C): ALLUSERS = 1
Property(C): SOURCEDIR = C:\Cisco\
Property(C): TARGETDIR = F:\
Property(C): LocalAppDataFolder = C:\Users\Pepsi\AppData\Local\
Property(C): ProgramFilesFolder = C:\Program Files (x86)\
Property(C): INSTALLDIR2 = C:\Program Files (x86)\VPN Client\
Property(C): ProfilesFolder = C:\Windows\
Property(C): PrintHoodFolder = C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(C): SendToFolder = C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\SendTo\
Property(C): PersonalFolder = C:\Users\Pepsi\Documents\
Property(C): WindowsFolder = C:\Windows\
Property(C): TempFolder = C:\Users\Pepsi\AppData\Local\Temp\
Property(C): FontsFolder = C:\Windows\Fonts\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): Cisco_Systems = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cisco Systems\
Property(C): RecentFolder = C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Recent\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): NetHoodFolder = C:\Users\Pepsi\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(C): ProgramFiles64Folder = C:\Program Files\
Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(C): SystemFolder = C:\Windows\SysWOW64\
Property(C): WinSxS = C:\Windows\
Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): MyPicturesFolder = C:\Users\Pepsi\Pictures\
Property(C): GAC = F:\
Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(C): FavoritesFolder = C:\Users\Pepsi\Favorites\
Property(C): INSTALLDIR1 = C:\Program Files (x86)\Cisco Systems\
Property(C): System64Folder = C:\Windows\system32\
Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(C): Drivers = C:\Windows\system32\Drivers\
Property(C): AppDataFolder = C:\Users\Pepsi\AppData\Roaming\
Property(C): accessible = C:\Program Files (x86)\Cisco Systems\VPN Client\accessible\
Property(C): Certificates = C:\Program Files (x86)\Cisco Systems\VPN Client\Certificates\
Property(C): include = C:\Program Files (x86)\Cisco Systems\VPN Client\include\
Property(C): Logs = C:\Program Files (x86)\Cisco Systems\VPN Client\Logs\
Property(C): Profiles = C:\Program Files (x86)\Cisco Systems\VPN Client\Profiles\
Property(C): Resources = C:\Program Files (x86)\Cisco Systems\VPN Client\Resources\
Property(C): TempInstall = C:\Program Files (x86)\Cisco Systems\VPN Client\TempInstall\
Property(C): updates = C:\Program Files (x86)\Cisco Systems\VPN Client\updates\
Property(C): System16Folder = C:\Windows\
Property(C): WWWROOT = F:\
Property(C): Cisco_Systems_VPN_Client = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Cisco Systems VPN Client\
Property(C): VersionNT = 601
Property(C): USERNAME = Pepsi
Property(C): DLLDIR = {467D5E81-8349-4892-9E81-C3674ED8E451}
Property(C): WiseCurrentWizard = Welcome_Dialog
Property(C): DLLLOC = C:\Users\Pepsi\AppData\Local\Temp\{467D5E81-8349-4892-9E81-C3674ED8E451}\
Property(C): DN_PkgSrcRev.dne.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = 53
Property(C): DN_BuildNumber.dne.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = 18002
Property(C): WiseEditorVersion = 7.3.0.250
Property(C): DN_DNE_InstallText.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = Managing Network Components|Installing Network Components. This may take several minutes.|Working {([1])}
Property(C): CRLF.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D =
Property(C): DN_DNE_Ver.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = 3.22.5.18001
Property(C): APPS_TEST = 1
Property(C): DN_DNE_RemoveText.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = Managing Network Components|Removing Network Components. This may take several minutes.|Working {([1])}
Property(C): DN_DNE_DoInstall.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = false
Property(C): DN_DNE_DoRemove.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = false
Property(C): D64_DNE.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = C:\Program Files\Common Files\Deterministic Networks\DNE\
Property(C): D64_DNCF.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = C:\Program Files\Common Files\Deterministic Networks\Common Files\
Property(C): D64_CFDetNet.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = C:\Program Files\Common Files\Deterministic Networks\
Property(C): CommonFiles64Folder.BEE04CD6_610D_4F5B_AC11_6AD2E290CC1D = C:\Program Files\Common Files\
Property(C): MsiLogFileLocation = C:\Cisco\log.txt
Property(C): PackageCode = {A8E53AA2-297F-4262-9996-753440EF4AB0}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = C:\Cisco
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 1668
Property(C): MsiSystemRebootPending = 1
Property(C): VersionDatabase = 200
Property(C): VersionMsi = 5.00
Property(C): VersionNT64 = 601
Property(C): WindowsBuild = 7600
Property(C): ServicePackLevel = 0
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): WindowsVolume = C:\
Property(C): RemoteAdminTS = 1
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): MsiAMD64 = 6
Property(C): Msix64 = 6
Property(C): Intel = 6
Property(C): PhysicalMemory = 4086
Property(C): VirtualMemory = 7031
Property(C): AdminUser = 1
Property(C): MsiTrueAdminUser = 1
Property(C): LogonUser = Pepsi
Property(C): UserSID = S-1-5-21-2390718941-902162640-429532733-1000
Property(C): UserLanguageID = 1033
Property(C): ComputerName = MEGA
Property(C): SystemLanguageID = 1033
Property(C): ScreenX = 1280
Property(C): ScreenY = 800
Property(C): CaptionHeight = 19
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 16
Property(C): TextInternalLeading = 3
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): Time = 23:29:33
Property(C): Date = 5/25/2010
Property(C): MsiNetAssemblySupport = 2.0.50727.4927
Property(C): MsiWin32AssemblySupport = 6.1.7600.16385
Property(C): RedirectedDllSupport = 2
Property(C): MsiRunningElevated = 1
Property(C): Privileged = 1
Property(C): DATABASE = C:\Cisco\vpnclient_setup.msi
Property(C): OriginalDatabase = C:\Cisco\vpnclient_setup.msi
Property(C): SourceDir = C:\Cisco\
Property(C): VersionHandler = 5.00
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
Property(C): CsProp_CopyInstHelperDll = 1
Property(C): CLIENT_INSTALLED = 0
Property(C): ROOTDRIVE = F:\
Property(C): CostingComplete = 1
Property(C): OutOfDiskSpace = 0
Property(C): OutOfNoRbDiskSpace = 0
Property(C): PrimaryVolumeSpaceAvailable = 124015160
Property(C): PrimaryVolumeSpaceRequired = 50274
Property(C): PrimaryVolumeSpaceRemaining = 123964886
Property(C): PrimaryVolumePath = C:
=== Logging stopped: 5/25/2010 23:29:34 ===
MSI (c) (84:50) [23:29:34:680]: Note: 1: 1708
MSI (c) (84:50) [23:29:34:711]: Product: Cisco Systems VPN Client 5.0.07.0290 -- Installation operation failed.
MSI (c) (84:50) [23:29:34:743]: Windows Installer installed the product. Product Name: Cisco Systems VPN Client 5.0.07.0290. Product Version: 5.0.7. Product Language: 1033. Manufacturer: Cisco Systems, Inc.. Installation success or error status: 1603.
MSI (c) (84:50) [23:29:34:758]: Grabbed execution mutex.
MSI (c) (84:50) [23:29:34:789]: Cleaning up uninstalled install packages, if any exist
MSI (c) (84:50) [23:29:34:836]: MainEngineThread is returning 1603
=== Verbose logging stopped: 5/25/2010 23:29:34 ===
05-26-2010 10:07 AM
No solution found, no expert consider. I finally decided to re-install Windows 7. After that, from a fresh Windows, the VPN client installation works well.
Ticket closed.
07-24-2013 08:25 AM
You should be able to install the 64 bit version of the Cisco VPN software
Latest version is vpnclient-winx64-msi-5.0.07.0440-k9.exe
Using Shrew VPN is a workaround more than a solution / answer to this issue.
You should download and run MCPR.exe first, to clean out any traces of McAfee products that conflict with Cisco VPN.
http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
If there is a problem with vbscript registration on the system - there is a fixit tool from Microsoft for that:
MicrosoftFixit50842.msi
