SPA 500 family
May 23rd, 2010
I have the SPA508 for 3 months now, running the latest firmware 7.4.4
I've noticed a change into the behaviour. An activity on the network, when the phone is idle !??!!
I can see LEDs from my switch blinking ( showing activities )
I had a look on the Status window of the phone... seen nothing
- Is there antbody having the same problem ??
- Any signs of activities ?
2) BTW, I also found the sending the number dialed with the # key, some time to time,  the phone freezes
Thanks for your help
Stephane
stevemag76 Tue, 05/25/2010 - 04:10
OK, I found the problem of the Blinking Switch..
I've changed the IP address of the phone and that works out :-)
I made a ping of the IP address and found nothing else on the LAN.. But Apparently, there is something ( wrong) on this IP address
Anyway, I found it :-)
( sorry for this stupide mistake  )
The sound on the Headset seems to be with too much bass
A bit more of treble would be greatly appreciate
Would be possible to fix this into the next Firmware ?
Steve
