cisco 2821 snmp No Such Object available on this agent at this OID
May 23rd, 2010
Hi Sir/Miss
i am using net-snmp on CentOS. when i try to using snmpwalk to get OID "1.3.6.1.4.1.9.9.166.1.5.1.1.2" from cisco 2821. it display No Such Object available on this agent at this OID.
i have cisco MIB "CISCO-CLASS-BASED-QOS-MIB" . it load at net-snmp. i run snmptranslate, it can successful. please look at below:
[[email protected]-logsvr mibs]# snmptranslate -m +CISCO-CLASS-BASED-QOS-MIB -IR -On cbQosConfigIndex
.1.3.6.1.4.1.9.9.166.1.5.1.1.2
[[email protected]-logsvr mibs]# snmptranslate -m +CISCO-CLASS-BASED-QOS-MIB -IR -On cbQosCMPostPolicyByte
.1.3.6.1.4.1.9.9.166.1.15.1.1.9
when i try to run snmpwalk , it retrun "No Such Object available on this agent at this OID" i check the mib locator in cisco website. it can support "CISCO-CLASS-BASED-QOS-MIB" . why i can't get OID?
[[email protected]-logsvr mibs]# snmpwalk -v 2c hostip -c snmpkey -m +all 1.3.6.1.4.1.9.9.166.1.15.1.1.9
CISCO-CLASS-BASED-QOS-MIB::cbQosCMPostPolicyByte = No Such Instance currently exists at this OID
koman.lei Sun, 05/23/2010 - 19:49
Hi Sir/Miss
my cisco 2821 router info:
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(11)T, RELEA
SE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-ipbasek9-mz.124-11.T.bin"
router cbwfq config:
  Policy Map QoS
    Class Precedence-5
      Strict Priority
      Bandwidth 1024 (kbps) Burst 25600 (Bytes)
    Class Precedence-4
      Strict Priority
      Bandwidth 192 (kbps) Burst 4800 (Bytes)
    Class class-default
      Flow based Fair Queueing
      Bandwidth 0 (kbps) Max Threshold 64 (packets)
interface Serial0/0/0:0
description Unframe E1 IPLC to HK
bandwidth 2048
ip address x.x.x.x 255.255.255.252
no ip unreachables
ip route-cache flow
load-interval 30
max-reserved-bandwidth 99
service-policy output QoS
BR/Man
