etherchannel issue
May 23rd, 2010
I've configured etherchannel on my switch but i can only ping the default vlan 200, but not other VLANs. This is a layer 3 switch - routing is enabled.
Any ideas?
interface Port-channel1
switchport trunk native vlan 200
switchport trunk allowed vlan 300,400,500
switchport mode trunk
interface GigabitEthernet1/0/1
channel-group 1 mode on
interface GigabitEthernet1/0/2
end
switch1#show etherchannel summary
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi1/0/1(P) Gi1/0/2 (P)
motorola#show etherchannel detail
                Channel-group listing:
I noticed the protocol does not show (is this normal?). Im running LACP between the switch and the Dell server.
Ganesh Hariharan Mon, 05/24/2010 - 00:26
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Any ideas?
end
You have configured ether channel between switch port and server NIC ? and in your switch side you have configured on mode for etherchannel that whay protocol isnot showing in summary command.
which vlan is server is placed ?
Hope to Help !!
Ganesh.H
glen.grant Mon, 05/24/2010 - 04:12
    You are not running LACP if you have the port channel set as on .  It would have to read "channel-group X mode active or auto "  to be using LACP.
